96db/ 845 powered
0 Members and 1 Guest are viewing this topic. Read 4507 times.
gregoh
96db/ 845 powered
« on: 21 Mar 2013, 11:57 pm »
I can't stress enough how the extra SET watts helps with headroom
T-90/ Radian 745 on cherry wave guide/ AE TD12M/ GR Research servo sub's
Greg
Freo-1
Re: 96db/ 845 powered
« Reply #1 on: 22 Mar 2013, 01:07 am »
Nice.  What amp/pre are you using?  (DIY?)
SET Man
« Reply #2 on: 22 Mar 2013, 01:25 am »
Hey!
   Nice looking system and room. :D
   Nice 845 amp... Bel Canto SET 40. A beauty and good sounding amp, and I should know. What 845 tubes and 12AX7s you have in it? Too bad they don't make it like this anymore. They have switched to the dark side... or should I say a bright side :lol:
   Where do you get the wooden horn from? Or you made them yourself?
Take care,
Buddy :thumb:
gregoh
« Reply #3 on: 22 Mar 2013, 02:10 am »
Modified Monarchy NM24 tube dac/preamp
I'm using 5751's instead of 12AX7  30% less gain and the Shangung 845B
Horns are DIY
Greg
SET Man
« Reply #4 on: 22 Mar 2013, 03:24 am »
Hey!
   Nice job on the wooden horns. :D
   BTW... where did you buy the 845B?
Take care,
Buddy :thumb:
gregoh
« Reply #5 on: 22 Mar 2013, 03:28 pm »
Thanks SET
Thetubestore
Greg
Freo-1
« Reply #6 on: 22 Mar 2013, 05:52 pm »
D'oh!  Now I see the amp in the pic.   :oops:
I think you are on to something special with this setup.   :thumb:
gregoh
« Reply #7 on: 22 Mar 2013, 07:54 pm »
Better shot
SET Man
« Reply #8 on: 2 Apr 2013, 04:30 am »
Hey!
    Nice amp indeed. :D Love the glow.
    Anyway, just curious... how is the sound of the Shuguang 845B compare to their standard 845? I've been thinking about getting a pair. Thanks.
Take care,
Buddy :thumb:
Gopher
« Reply #9 on: 8 May 2013, 03:56 am »
The 845B is a dramatic upgrade to the stock Shuguang 845As.  In fact, I prefer it significantly to the Psvane 845 as well.
Here is a nice review I agree with:  http://www.positive-feedback.com/Issue15/845.htm
"The sonic differences between the new Shuguang 845Bs and the standard 845s are not subtle. It is like going from a $1500 preamp to a $4000 preamp. You can enjoy the music through both, but once you have heard the $4000 preamp it is hard to go back to the cheaper one."
vortrex
« Reply #10 on: 8 May 2013, 04:02 am »
What is it that you like better than the Psvane?  My amp uses the HiFi series.
Andy831
« Reply #11 on: 14 Jun 2013, 06:44 am »
Hi Gregoh
My first post and thought I would pitch in here as I have just bought a Bel Canto Set 40.
I took the 845's out to give the amp casework a bit of a clean up and only noticed on reassembly that both 845 valves are numbered in permanent marker pen. My understanding (being strictly non techie) is that this amp has a self biasing circuit, in which case what is the point of numbered valves?
Hope you can help
Andy
