Von Schweikert VR-22 Break In
0 Members and 1 Guest are viewing this topic. Read 2486 times.
ASMAN
« on: 21 Mar 2013, 09:10 pm »
After two months of breaking in the VR-22's just keep getting better.
Probably have 300 hrs on them by now.
On first listen the soundstage was narrow, vocals shrill at times. But now they are coming into their own and I expect they will continue to improve for a while.
I need to do some room tuning though. I have a mid bass hump that is annoying but other than that things are very good. I don't know what frequency it is so I don't know how to handle it. Any suggestions?
I can recommend these speakers with confidence to anyone who wants superior sound on a budget.
JackD201
Re: Von Schweikert VR-22 Break In
« Reply #1 on: 22 Mar 2013, 03:50 am »
Hi ASMAN you can download an RTA app for your smartphone. Not the most precise compared to say a Phonic unit or calibrated mics and analysis software but it should get you in the ballpark. Have fun!  :thumb:
BigSwede
« Reply #2 on: 22 Mar 2013, 01:21 pm »
At 300 hours you are just getting to the good part, if my experience with the VR-33s can be any guide.
I seem to recall some bass bloom that went away later in the break in process, though that was much earlier than 300 hours. But the drivers are different too, so it is still possibile the bass response will smooth out soon. Perhaps some port stuffing might be in order, I am sure VSA can advise you on that.
Albert Von Schweikert
    • Von Schweikert Audio
« Reply #3 on: 22 Mar 2013, 05:27 pm »
The distance of the back wall to the rear of the VR-22 is part of the "tuning," so you might want to experiment with placement first.  At 500 hours you may need to install more Dacron into the vent, but push it past the vent into the bass chambers.  That Scanspeak 8" woofer is far more powerful than any other small woofer/midrange we have ever seen or tested, so it will really energize the room like a very large floor standing model.  However, the speaker itself is flat in response down to 32Hz.
Of course, if your room has dimensional ratios that introduce peaks into the sound due to standing wave Eigentones, you will need to either change speaker/listening positions or build some bass traps specifically tuned to the frequency of the peak.  If you see the bass response graph of the VR-22 (published on our Facebook page) which was taken in our semi-anechoic chamber, the response is close to ruler flat.  The speaker isn't causing your room to lift the bass at certain frequencies, the dimensional ratios of your room are the issue.  Call us at the factory for assistance, we're here to help.
Happy Listening,
Albert
