Anti-skating
0 Members and 1 Guest are viewing this topic. Read 20676 times.
jimdgoulding
Re: Anti-skating
« Reply #60 on: 2 Apr 2013, 01:20 am »
Ok, then, thirds it is.  After this discussion, I think I'm good to go with anti-skating.  Hope you are, too
So, I took a flashlight and put it on a table just behind my turntable.  Windexed a round mirror out of its frame bout as thick as an average record and put it on my mat nearest the edge to me.  Got down on a knee, turned on the flashlight, pointed it to my location, and lowered my stylus to the surface of the mirror.  Now, I can see the stylus in both directions very clearly with the help of my Radio Shack magnifying tool.  I can even see it's tip.
I'm bad!  That's right, I'm bad!  I'm so bad I'm powerglide!
cheap-Jack
Re: Anti-skating
« Reply #61 on: 2 Apr 2013, 02:55 pm »
Hi.
(1) Peter Ledermann from Soundsmith was at VPI 2 weekends ago giving a seminar, of sorts. His take on anti-skate (his words, not mine, and also spoken in the presence of VPI) was that anyone who says anti-skate isn't necessary doesn't know what they are talking about.
(2) That being said, it is also near impossible to set it correctly across the entire side of a record, because it keeps changing. But without it you will get uneven pressure on one side of the stylus tip, wearing both the stylus and the record grooves.
(3)His method was to use the "blank" record trick. The arm should move ever so slightly in toward the center. That is a reasonable approximate setting per Peter.
(1) 100% agreed. As I posted earlier here, this is physics. Anti-skating force in NEEDED to offset
      the centripetal force which keep a object moving a certain uniform speed along a curved path.
      Same applies to a cartridge/stylus tracking a LP.
(2) Yes, otherwise the inner side of the record grooves will be worn out due to the centripetal force
     caused by the moving stylus. No jokes.
(3) Yes, I agreed 100%. I used a blank vinyl disc to simulate the hardness & surface friction of our
     vinyl LPs. By adjusted to the right AS force of the dial scale (disregarding what is shown on the
     dial scale), I can have the tonearm set stationary tracking at difference positions
     across the entire disc from 1/3 from the outer rim to the innermost possible tracking area.
     Given a thicker & well done blank disc instead of my DIYed experimenting disc being much thinner the standard thickness of an LP, the result I would consider pretty promising. If I rebuilt a blank vinyl disc of the same thickness & mass & stiffness of a LP, I believe my tonearm could track
stationary at any position across the blank disc with the proper AS setting.
     I've noted the AS reading as set by such blank disc tracking is a bit higher than the setting as recommended by the TT SA dial scale.
c-J
