0 Members and 1 Guest are viewing this topic. Read 5260 times.
Certainly a concern for DSD files. There is significant damage done when downrez'ing from DSD to PCM. Don't do it if you don't have to.
I use the miniDSP, and going from pure DSD to PCM is lossy, no doubt about it. The real question is whether the losses from the conversion are outweighed by the advantage of being able to get rid of your passive crossovers. IMO, it is. If you are going fully active, the miniDSP is a great (and inexpensive) solution. On the other hand, if you are just using it for EQ functions and not for going active (ie, you are keeping your passive crossovers in place), then ted is absolutely right - analog EQ and/or room treatments all the way!
I just put the miniDSP in the system a few days ago and am still in the learning mode. However, what I am ultimately trying to do is institute an active crossover to seam the gap between a pair of full rangers and a pair of OB subs. The way I have it figured, I can go about accomplishing this at least a couple of ways. One of those ways is to simply let my full rangers do their thing and just apply high and low passes to the subs, leaving the signal to the full rangers pristine. But, I'm not sure this is the best way to go in regards to best implementing the miniDSP's ability to give me those steep filters that going active can achieve.Anyway, I don't mean for this to be a discussion on implementing active crossovers. Just curious about signal degradation.
Certainly a concern for DSD files. There is significant damage done when downrez'ing from DSD to PCM. Don't do it if you don't have to.Personally, I'd much rather involve analog EQ if needed, or simple room treatments, rather than the deliterious digital-to-analog-to-digtal-to-analog. Think about it, the music you are likley listening to has already ahd that done to it before you even get it in the system..
I played around with a MiniDSP module a while back. The functionality for the price and the size is very impressive. Digital latency is pretty low, and sound quality is pretty good. But on my system I still got the same filet mignon in, hamburger out results that I've experienced with other DSPs. My subs aren't OB, but I have six of them "swarmed" around the room, and I need electronic XO and EQ to get them blended correctly. I've tried digital EQs from Behringer, DBX, and the above-mentioned MiniDSP, but could never get the subs to sound right or integrate properly. I'm now using two analog Behringer units on my subs, an electronic XO and a parametric EQ and I've got the integration nailed.One issue with DSP units is input/output gain structure. You have to drive the input to a certain level to get the signal encoded properly by the ADC. Too low and the signal gets encoded at less than 16 bits of resolution, too high and the input overloads. Not a big deal with a pre-volume control line level signal. But putting a DSP unit on the output of a preamp means at low volume levels the DSP is encoding/decoding at low bit resolution and at high volume levels the input is clipping. An analog processor with low noise and lots of headroom sidesteps these issues. I think this, along with latency issues, is why DSP on my subs has not worked as well as the analog processors.Russ
so this is your ultimate solution?:
Model numbers?
