Squeezebox help needed again.
0 Members and 1 Guest are viewing this topic. Read 2337 times.
gongos
« on: 17 Mar 2013, 06:46 pm »
Once again I've entered into the rebuffering nightmare. I've reinstalled and restarted everything multiple times and installed older versions of LMS. Nothing has made a difference. I did install norton, but everything work when I first installed it and the firewall is giving it access. Here's the last server log:
[13-03-17 11:22:50.7950] main::init (350) Starting Squeezebox Server (v7.6.1, r33110, Wed Aug 17 18:52:34 PDT 2011) perl 5.010000
[13-03-17 11:22:51.3410] Slim::Schema::Storage::throw_exception (119) Error: DBI Exception: DBD::SQLite::db selectrow_array failed: no such table: sqlite_stat1 [for Statement "SELECT COUNT(*) FROM sqlite_stat1 WHERE tbl = 'tracks'"]
[13-03-17 11:22:51.3413] Slim::Schema::Storage::throw_exception (119) Backtrace:
   frame 0: Slim::Utils::Log::logBacktrace (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Schema/Storage.pm line 119)
   frame 1: Slim::Schema::Storage::throw_exception (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>DBIx/Class/Storage/DBI.pm line 1006)
   frame 2: DBIx::Class::Storage::DBI::__ANON__ (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Utils/SQLiteHelper.pm line 356)
   frame 3: (eval) (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Utils/SQLiteHelper.pm line 356)
   frame 4: Slim::Utils::SQLiteHelper::postConnect (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Schema.pm line 295)
   frame 5: Slim::Schema::_connect (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Schema.pm line 129)
   frame 6: Slim::Schema::init (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Music/Import.pm line 637)
   frame 7: Slim::Music::Import::_checkLibraryStatus (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Music/Import.pm line 569)
   frame 8: Slim::Music::Import::useImporter (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Music/MusicFolderScan.pm line 51)
   frame 9: Slim::Music::MusicFolderScan::init (slimserver.pl line 518)
   frame 10: main::init (slimserver.pl line 639)
   frame 11: main::main (slimserver.pl line 99)
   frame 12: PerlSvc::Interactive (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>PerlSvc.pm line 99)
   frame 13: PerlSvc::_interactive (slimserver.pl line 0)
   frame 14: (eval) (slimserver.pl line 0)
[13-03-17 11:22:51.3414] Slim::Utils::SQLiteHelper::postConnect (359) Optimizing DB because of missing or empty sqlite_stat1 table
[13-03-17 11:22:51.3465] Slim::Schema::init (154) Warning: Creating new database - empty database or database from 6.3.x found
[13-03-17 11:23:01.8251] Slim::Plugin::MusicMagic::Plugin::initPlugin (268) Can't connect to port 10002 - MusicIP disabled.
[13-03-17 11:23:02.3950] main::checkDataSource (1050) Warning: Schema updated or no tracks in the database, initiating scan.
[13-03-17 11:24:19.1411] main::init (350) Starting Squeezebox Server (v7.6.1, r33110, Wed Aug 17 18:52:34 PDT 2011) perl 5.010000
[13-03-17 11:24:19.7651] Slim::Control::Request::execute (1863) Request in error, returning
[13-03-17 11:28:32.9933] Slim::Schema::Storage::throw_exception (119) Error: DBI Exception: DBD::SQLite::db do failed: database is locked [for Statement "DELETE FROM progress"]
[13-03-17 11:28:32.9940] Slim::Schema::Storage::throw_exception (119) Backtrace:
   frame 2: DBIx::Class::Storage::DBI::__ANON__ (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Utils/Progress.pm line 351)
   frame 3: Slim::Utils::Progress::clear (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Music/Import.pm line 268)
   frame 4: Slim::Music::Import::clearProgressInfo (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Utils/SQLiteHelper.pm line 485)
   frame 5: Slim::Utils::SQLiteHelper::_notifyFromScanner (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Control/Request.pm line 1878)
   frame 6: (eval) (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Control/Request.pm line 1878)
   frame 7: Slim::Control::Request::execute (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Web/JSONRPC.pm line 408)
   frame 8: Slim::Web::JSONRPC::requestMethod (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Web/JSONRPC.pm line 212)
   frame 9: (eval) (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Web/JSONRPC.pm line 212)
   frame 10: Slim::Web::JSONRPC::handleURI (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Web/HTTP.pm line 488)
   frame 11: Slim::Web::HTTP::processHTTP (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Networking/IO/Select.pm line 139)
   frame 12: (eval) (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Networking/IO/Select.pm line 123)
   frame 13: Slim::Networking::IO::Select::__ANON__ (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Networking/IO/Select.pm line 184)
   frame 14: (eval) (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Networking/IO/Select.pm line 184)
   frame 15: Slim::Networking::IO::Select::loop (slimserver.pl line 691)
   frame 16: main::idle (slimserver.pl line 641)
   frame 17: main::main (slimserver.pl line 99)
   frame 18: PerlSvc::Interactive (/<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>PerlSvc.pm line 99)
   frame 19: PerlSvc::_interactive (slimserver.pl line 0)
   frame 20: (eval) (slimserver.pl line 0)
[13-03-17 11:28:33.0020] Slim::Control::Request::execute (1883) Error: While trying to run function coderef [Slim::Utils::SQLiteHelper::_notifyFromScanner]: [Carp::Clan::__ANON__(): DBI Exception: DBD::SQLite::db do failed: database is locked [for Statement "DELETE FROM progress"] at /<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Schema/Storage.pm line 123
[13-03-17 11:28:33.0025] Slim::Web::JSONRPC::requestMethod (413) Request failed with error: Bad dispatch!
[13-03-17 11:29:37.6976] Slim::Schema::Storage::throw_exception (119) Error: DBI Exception: DBD::SQLite::db do failed: database is locked [for Statement "DELETE FROM progress"]
[13-03-17 11:29:37.6980] Slim::Schema::Storage::throw_exception (119) Backtrace:
[13-03-17 11:29:37.6983] Slim::Control::Request::execute (1883) Error: While trying to run function coderef [Slim::Utils::SQLiteHelper::_notifyFromScanner]: [Carp::Clan::__ANON__(): DBI Exception: DBD::SQLite::db do failed: database is locked [for Statement "DELETE FROM progress"] at /<C:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Schema/Storage.pm line 123
[13-03-17 11:29:37.6986] Slim::Web::JSONRPC::requestMethod (413) Request failed with error: Bad dispatch!
shadowlight
Re: Squeezebox help needed again.
« Reply #1 on: 17 Mar 2013, 08:22 pm »
try disabling norton for couple of minutes and see if the problems go away.   if it does you might have to exclude the lms install and db directory from nortons virusscan.
gongos
« Reply #2 on: 22 Mar 2013, 12:41 am »
Internet radio works.
Flac files from my hard drive rebuffer and won't play.
AB
« Reply #3 on: 22 Mar 2013, 01:51 am »
Maybe we went over this the first time but where are your music files located - NAS, HD?
When was the last time your Music scanned successfully? Did you initiate it?
How full is the drive that contains your music?
Can you access Mysqueezebox.com?
I'm just riffing here but these are the things I would be asking myself if I were in your shoes.
gongos
« Reply #4 on: 22 Mar 2013, 03:34 am »
externa hd
scanned today, not sure what initiating it means
hd is half full
i can access mysqueezebox.com
lms works from the laptop not the pc.
AB
« Reply #5 on: 22 Mar 2013, 04:45 am »
So it scanned your music completely and successfully but when you run LMS it loops and you get that log. Correct?
Have you checked the scanner log? I'm wondering if the scan had any issues.
It seems the db can become corrupted if the scan is interrupted by certain plugins accessing the db during the scan. Maybe. How big is your music folder? How long has it been taking to do a complete scan? Are you working on the pc while a scan is in progress? Is norton doing something in the background while the scan is in progress?
What do you mean LMS runs from the laptop but not the pc?
You initiating the scans means you selected "Clear Library and rescan everything."
gongos
« Reply #6 on: 23 Mar 2013, 05:26 am »
I'll look at all this later.
But when I do no scan. The internet radio plays fine, but when I scan the files the files rebuffer and the radio rebuffers. So it's something to do with the scan and/or the files on the hd.
The hd has 1tb of flac files on it. Half the drive.
