W-Frame dimensions
0 Members and 1 Guest are viewing this topic. Read 1486 times.
bdp24
W-Frame dimensions
« on: 16 Mar 2013, 03:30 am »
Is it my computer, or have the dimensions in the W-Frame drawings for the SW-12-16FR gone missing?
Danny Richie
Re: W-Frame dimensions
« Reply #1 on: 16 Mar 2013, 02:20 pm »
Measurements are on there. Must be your .pdr viewer. I can e-mail them to you if you like.
bdp24
« Reply #2 on: 16 Mar 2013, 07:32 pm »
That would be great Danny. It's odd.....the drawings are there, and the lines with arrows are too. Just not the numbers of the dimensions.
« Reply #3 on: 17 Mar 2013, 04:09 am »
I'm seeing the same thing when clicking on the link at the GR website
Only  when viewing  with the browser plugin.
If I save the same file locally , then open it here, I see everything  so it is obviously a plugin issue.  Maybe try saving  the file  to your PC then opening it
-jay
bdp24
« Reply #4 on: 17 Mar 2013, 05:11 am »
Thanks Jay, I'll try that.
