HT 1 speaker bing posts
0 Members and 1 Guest are viewing this topic. Read 5142 times.
mdfoy
« on: 14 Mar 2013, 08:20 pm »
The bottom pair of speaker binding posts on my HT 1 are little loose. Not too loose, just a little wiggle, but it is there.  I haven't noticed any difference in sound quality. Is this disaster waiting to happen?
jsalk
Re: HT 1 speaker bing posts
« Reply #1 on: 14 Mar 2013, 08:41 pm »
If you remove the six screws holding the plate in place, you can pull it out and tighten the plastic nut that holds the binding posts in place.  It probably came a little loose over time.  Should be an easy fix.
- Jim
mdfoy
« Reply #2 on: 15 Mar 2013, 09:54 pm »
Jim,
Thanks! You are the best.  :thumb:
Mike
mdfoy
Re: HT 1 speaker binding posts
« Reply #3 on: 26 Oct 2013, 03:03 am »
I have to reopen this post.
I have tried to remove the speaker binding post panel, but it is REALLY tight.  I don't want to pull too hard for fear of seriously damaging the speakers. I even tried going in through the woofer.  Same deal, it is like they are stuck into the cabinet. Anyone experience this and fixed it?
jsalk
« Reply #4 on: 26 Oct 2013, 10:21 am »
mdfoy -
Almost all materials expand and contract with changes in temperature and humidity.  The recess for the binding post plate is a snug fit.  Over time, it can become even more snug, which is you are experiencing.
Here is what we would do.  Fashion a stick that is 3/4" x 3/4" x about 16 - 18" long.  Remove the woofer and run the stick through the woofer hole to the rear of the binding post plate.  While someone is holding the plate and terminals at the rear of the speaker, use a hammer to tap on the stick and drive the plate loose.  Increase the tap pressure until the binding post plate comes loose.  It eventually will.
This is the technique we use when faced with this situation.
- Jim
jtwrace
    • TIPP YouTube Channel
« Reply #5 on: 26 Oct 2013, 12:37 pm »
[size=78%]Here is what we would do.  Fashion a stick that is 3/4" x 3/4" x about 16 - 18" long.  Remove the woofer and run the stick through the woofer hole to the rear of the binding post plate.  While someone is holding the plate and terminals at the rear of the speaker, use a hammer to tap on the stick and drive the plate loose.  Increase the tap pressure until the binding post plate comes loose.  It eventually will.[/size]
- Jim
You don't have to worry about an edge getting caught and lifting the veneer in one spot?
TF1216
« Reply #6 on: 26 Oct 2013, 12:56 pm »
Jim, do you have a trick for removing drivers when the are stuck?
mdfoy
« Reply #7 on: 26 Oct 2013, 03:12 pm »
Jim,
I tried going throught he woofer as well.  It is stuck too, and I amost ripped the veneer trying to get it out.
jsalk
« Reply #8 on: 26 Oct 2013, 03:43 pm »
That is the reason you would want someone holding the binding posts from the rear.  They can prevent it from hitting the edge.  There is always a chance something can happen, but we have never had an issue.
We have a tool we use here at the shop.  It is like a pick with a curved tip.  Kind of like a nut pick in an old nutcracker set.  We insert it in a screw hole, drive it slightly under the driver or binding post faceplate and pry upwards.  Sometimes it takes a little work, but it will eventually pop loose.
- Jim
stlrman
« Reply #9 on: 26 Oct 2013, 04:46 pm »
That wood is insane !! :thumb:
Let's see the front please.
mdfoy
« Reply #10 on: 26 Oct 2013, 10:02 pm »
stlrman
Here is a shot from my gallery
Jim,
Is there a source for a tool that you describe?
jtwrace
« Reply #11 on: 26 Oct 2013, 10:05 pm »
WOW, those are stunning!  What kind of veneer is that?
Big Red Machine
« Reply #12 on: 26 Oct 2013, 11:38 pm »
Looks like my first pair of HT3's in Waterfall Bubinga.
Rocket
« Reply #13 on: 27 Oct 2013, 12:03 am »
Hi BRM and Mike,
I never quite had enough money to 'pony up' for a pair of speakers with waterfall bubinga and its one of the nicest finishes that Jim does.  I hope your careful with the veneer it would be a shame to damage it.  Are the loose binding posts that much of an issue?  Do you swap cables all the time?
Cheers Rod
jtwrace
« Reply #14 on: 27 Oct 2013, 01:02 am »
After another look...does anyone else see the face in the middle of the speaker?  It's wild!
jsalk
« Reply #15 on: 27 Oct 2013, 10:51 am »
stlrman
Jim,
I don't recall where we got it (probably someplace like Harbor Freight) or what it was.  It was from a selection of picks and one was curled up at the end.  It just so happens to work quite well for this task.  But I have no idea where it came from.  So I hope we never brake it because I don't know how we'd replace it.
- Jim
MichiganMike
« Reply #16 on: 27 Oct 2013, 12:28 pm »
- Jim
Harbor Freight offers a couple of inexpensive pick sets that may do the job if used with care.
http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html
http://www.harborfreight.com/7-piece-pick-and-hook-set-93958.html
jsalk
« Reply #17 on: 28 Oct 2013, 12:19 pm »
mrhyfy
« Reply #18 on: 28 Oct 2013, 02:26 pm »
I've used a large wood screw about a number 12..FINGER tightened into one of the woofer holes then gently tugged upon.Maybe work your way around the woofer tugging on different screw holes.  No special tool needed.
