0 Members and 1 Guest are viewing this topic. Read 12591 times.
Thanks, Ryan. The veneered inserts in your photo arrived ok. I do like the cleaner look of the black, but it's good to have the matching veneered ones too.
ok, as a Vapor customer I have to ask this...why don't you cut the tops of the speaker stands to match the lines of the cabinets? every time I see Cirrus on stands it drives my eyes crazy!
So you can get your fingers under it to lift off the stands. Rear hand goes in the port, front hand goes there. When you're sitting listening they appear to be even with each other, or the front edge of the stand just disappears in the shadow.
Awesome looking speakers!!! Is this a redwoodburl veneer?Congrats! What amp are you going to run with them?
WOW they look great, congratulations! I know how you must have felt before receiving these, it is a very exciting experience. Mine should be on their way soon, but have a long travel ahead of them. Let us know how they sound!
I will definitely write up some impressions of the sound. They only had two hours on them before Ryan shipped them, so I had them running all day while at work. The bass is filling in; things sounding even more organic. I am very happy with how they are sounding. They are clearly an improvement on the Salk HT1-TLs (and in a different price range), but I'll hold off on any more detailed comments because most of the break in is yet to come. Clarity is already exceptional and the best I've had in my room (without being at all fatiguing).
Wow, those are stunning. Nice wood.
His pair of Cirrus are probably around 6k like mine. The xvr's may be close to 1k each.
Yes, I should have noted that. My Cirrus Blacks were $6K and the HT1TL was 50% less expensive and did not have the RAAL but the LCY ribbons Jim was using when I bought them.
