0 Members and 1 Guest are viewing this topic. Read 3675 times.
An active preamp is really the heart of an audio system, IMO. A passive preamp would be better than a poor quality active preamp,... but active preamps provide the additional amplification, filtering and isolation that are essential to achieve the best performance from a power amplifier and speakers. Every component is important, of course; crap in = crap out, etc., but in a well-balanced system, an active preamp plays an enormous role.
Hi.How can an active preamp 'achieve the best performance" when they generate harmonic, phase distortions & noise to contaminate the music??So an active preamp will change the equation to "crap in = MORE crap out". This is physics.c-J
A preamplifier must be able to isolate the normally very poor load driving capabilities of your source components and drive the shit out of whatever cables and amplifier)s) you have downstream. This requires a low output impedance and high drive current capability.A really good preamp will also isolate the amplifier and speakers from out of band signal garbage so you amp and speakers don't have to amplify crud, which is much harder to amplify than music.Finally the preamplifier's audio circuits must not screw up the source music or change it in any way (except for the use of tone controls if these are needed to help out lame speakers or horrid source material).Note that a passive preamp cannot do any of the functions above. However, a really good passive preamp might be more desirable than a ho-hum active preamp if you don't mind its significant limitations.Note that a good preamp is not supposed to be a music tweaking device. If it obviously changes the sound, it is not doing its job well.Regards,Frank Van Alstine
