0 Members and 1 Guest are viewing this topic. Read 8367 times.
I used EAC for a long time, it was considered the best ripper.I started using dbpoweramp a little while ago, much easier to rip to flac, IMHO.Costs a few bucks, but I think it's worth it because of ease of use.And flac or another uncompressed format is the way to go for SQ.Randy
I used to use EAC and iTunes (for applelossless) and now use dbpoweramp. DBPoweramp will automatically download album art and track info. The one other thing with dbpoweramp is that it does a checksum of the ripped file and compares it with it's database to let you know if the rip was accurate or not. I purchase the family pack version which I believe gives you the ability to install it on either 3 or 5 systems.
Thanks for reminding me of the accurate rip stuff.I have only used EAC and DBPoweramp. I actually used EAC with an addon called React for a long time. It basically did what I wanted, but was kind of a pain to setup, and if I changed PC's I had to remember how to set it up again.
DBPoweramp was really easy to setup. It has a 15 day free trial, with full functionality, so you can try it and have nothing to lose.
The accurate rip stuff ensures that you get a good rip. I think I enabled secure rip (or something like that), which has one drawback. If the CD is kind of obscure, so DB had trouble getting a database match, it will rip it over and over again, I think I have seen over 10 rips at times. This obviously takes a while, so some CD's end up taking a long time, but you know it is a good rip. If the CD is in the database, on my 2 year old dell laptop, rips are fast.No idea about WMP since I haven't used it, but my thought on it is that ripping a collection takes a long time. I would rather use a tool that has a good rep than one that I am not sure about. Randy
One more thing, dBPower amp is the only ripper I know of that allows you to choose an "uncompressed" Flac level (along w/ WAV of course, a few of us who are'nt spinning any type of discs anymore "cringe" at the word "compression" . It's the audiophiles version of "Liver")
I suggest not using the WMP format, it does not have the wide support of formats like FLAC, WAV or AIFF. If you want to store meta-data, which I believe you do, FLAC and AIFF are your best options. And yes, another vote for dBPoweramp.
I recommend a media player:Supporting a verity of formats including open formats like FLACAllows you to choose different audio drivers like ASIO and WASAPIiTunes and WMP don’t fulfill all these criteria.Have a look at JRiver Media Center (paid, my personal preference), JRiver Jukebox (free), Foobar or a very elegant piece of freeware like MusicBee
I recommand dBpowerampIt is fast and stableIt supports AccurateRipMeta data from AMG, GD3, MusicBrainz and FreeDBA reliable format converterI recommend FLAC as it is lossless, good support for tagging and has a checksum allowing verifying possible corruption of the data afterwardsThis requires a media player with support for FLAC.I recommend a media player:Supporting a verity of formats including open formats like FLACAllows you to choose different audio drivers like ASIO and WASAPIiTunes and WMP don’t fulfill all these criteria.Have a look at JRiver Media Center (paid, my personal preference), JRiver Jukebox (free), Foobar or a very elegant piece of freeware like MusicBee
As this is the second time you are ripping your CDs and I presume you don't want to do it a third time, I'd suggest developing a strategy that will last you a long time.That means ripping in a lossless format, storing it somewhere and backing it up. You can always convert to a lossy format from that, but you can't do the reverse.Here's a long article about developing a strategy:http://www.computeraudiophile.com/content/309-computer-audiophile-cd-ripping-strategy-and-methodology/I use EAC because it's what I know! I'm never sure how to interpret AccurateRip but as long as EAC says 'no errors' I accept it. Occasionally I get 'timing errors' on tracks. If it's just one timing error I usually can't hear anything wrong, but on occasions I've had a dozen or so timing errors on a particular track, and that translates as stuttered sound. The CD itself plays fine. Even if I clean the CD or use another CD tray, I get the same timing errors, yet if I use Nero to rip it, it plays perfectly. Fortunately, this doesn't happen very often.
My comment/question is in regards to the bolded phrase above. I use DBPoweramp but didn't know that it can be set to automatically download album art. How does one configure this? Thanks, Garth
