0 Members and 1 Guest are viewing this topic. Read 19819 times.
I think I might like the Hall & Oates songs better, kind of takes me back to when I was a kid and I used to spin my dad's H&O records.
You can check out artists here as well...at Daryl's house... http://www.livefromdarylshouse.com/http://www.livefromdarylshouse.com/archive.html
My favorite is the one with Grace Potter.
Pandora and Spotify are great for finding new music. Put in something you like and let it do the work. I have recently found:Starfuckerhttp://youtu.be/5Z8oYH_bhnASBTRKThttp://youtu.be/ZdUINbi4wSY
BTW, I know this should be obvious , but how do you make a hyperlink in a post, you know, with the name of something, let's say, but it links out to a page? I keep tying the 'insert hyperlink' button, but I must be missing something...
Not really obvious, I picked it up studying the posts of the esteemed Mr. Lonewolf. Select the insert hyperlink button, backspace over the last '[' in the first 'url' , replace with an '=' , ('url='), do your control 'V' to copy the http address, then replace the closing ']', then type in whatever name, title, etc you want in front of the last '/url'. (Note that I've replaced the bracket with apostrophe to prevent it from showing as a link.) Hope this helps, you can also see how it really looks by selecting 'quote' on a post that has an example matching what you want to do, and review the 'url' line info. Sbtrkt or Samples or ?
