0 Members and 1 Guest are viewing this topic. Read 8062 times.
Chris,Don't forget that the balanced version of the Pulsars is actually a double run + the awesome Furutech Rhodium connectors (which alone are $150 male/female pair). This makes them much better than the standard RCA Pulsar.Are you just going to try the Pulsar as an analog ic?George
Sorry, I meant the Pursang, and said Pulsar...
Carlman,In a revealing system, the differences aren't subtle. Try to find a more revealing system and report back on what you hear.Also, from talking to Chris, the balanced Pulsars are supposed to be significantly better than the rca version.BTW, do you hear a bit of grain at the top end at times?George
One point concerning the Pulsar's. I ordered two pairs of 1.5m IC's. Came in two separate bags. I shipped out one bag to Carlman to try , and I held the other. Short time later, PM from Carl, did you notice one IC cable is 1/2 inch longer than the other. Sure enough, checking my pair , 1/2 inch difference between the two cables. That metric stuff will throw you off all the time.
Chris- On your website you say the balanced cable can't be used for digital AES/EBU. If the singe IC can do 75 ohm SPDIF, why couldn't two runs of it do 150 ohm AES/EBU?
