Jungson Impression II CD Player - SOLD
0 Members and 1 Guest are viewing this topic. Read 1886 times.
reedlom
« on: 10 Mar 2013, 10:50 am »
I'm the second owner of this CD player. Asking $1200. I replaced the factory-installed 6922s with an NOS pair of Amperex 7308s. I have the factory double box/packing materials, remote, power cord and owner's manual. I will ship only within CONUS. Buyer will be responsible for shipping/insurance charges and 3% PayPal fee. Here is pertinent info on the CD player ... The Impression II uses two PCM1794 and ten OPA604 chips as the D/C and I/C converters in JungSon unique fully balanced 2-channel analog sound circuits. The Impression II can upgrade CD signal formats from 44.1 kHz/16 bit to192 kHz/24 bit. Users can select three sampling rates, the 44.1 kHz, 96 kHz and 194 kHz, according to their music taste. The Impression II’s circuit boards and power suppliers are located in five completely isolated aluminum alloy chambers to minimize the internal electronic interference. The solid aluminum alloy body with a triple chromed stainless steel top panel of the Impression II diminishes internal vibrations. The Impression II provides two separated valve outputs, one for your amplifier and the other for your headphones. Specifications Frequency response: 2Hz--20kHz Signal to noise ratio: ≥ 100dB Total harmonic distortion: ≤ 0.001% Audio outputs: Balanced XLR terminals, Non-balanced solid state RCA terminals, Non-balanced valve RCA terminals, Valve headphone FET terminal, Optical terminal, Coaxial PCM terminal, AES/EBU terminal Size: 430mm(L) X350mm(W)X 178mm(H) Net weight: 23kg. Prospective buyers can check my Audiogon feedback under user name reedlom.
« Last Edit: 3 Jul 2013, 12:22 pm by reedlom »
revrob
Re: Jungson Impression II CD Player
« Reply #1 on: 23 Mar 2013, 02:25 pm »
Great looking CD player. If only I had some extra funds. Good luck with the sale.
