JungSon JA88D-09 Integrated Class A Amplifier - SOLD
0 Members and 1 Guest are viewing this topic. Read 1359 times.
reedlom
I'm the original owner of this integrated amp. Asking $950. It has approximately 400 hours of play time. Here is the pertinent information on it ... The JungSon JA88D-09 is an improved version of JungSon’s JA88D-03 Fully Balanced Class-A integrated Amplifier. While keeping all the features of the original amplifier, the new version has a built-in phono stage. The new phono input is switchable between moving-coil (MC) and moving-magnet (MM) modes. The 88D-09 also adds an extra line output to make it easy to connect to external recording components or to other amplifiers and subwoofers. The JA88D-09 has a fully balanced and zero negative feedback circuit and is rated with a power output of 80-watts per channel, which is delivered in pure Class-A power. It has one balanced (XLR) input and four RCA inputs, and two pairs of speaker outputs for bi-wiring. Features: JungSon's unique Class A, full-balanced and non-negative feedback circuit 80 W class A output per channel One balanced (XLR) input, four RCA inputs and an extra line output for recording Built-in phono stage switchable between MC and MM modes Two pairs of speaker outputs for bi-wiring JungSon's unique designed heat sink - a 1.8 m2 copper radiator Fully sheathed and anti-shock aluminium alloy case Ocean blue LED power meters Specifications Power: 80W per channel (Class A, RMS 8 Ω) THD: ≤0.05% (1 kHz/1W) S/N ratio: ≥ 100 dB Frequency response: 20 Hz -20 kHz (± 0.5dB) Input impedance: 100k Ω Output impedance: 4-8 Ω Voltage: 240 ± 10 % Size (LxWxH): 470×430×190 mm Weight: 29.5 kg. I have the factory double box/packing materials, remote control, power cord and owner's manual. I will ship only within CONUS. Buyer will be responsible for shipping/insurance charges and 3% PayPal fee. Prospective buyers can check my Audiogon feedback under user name reedlom.
« Last Edit: 3 Jul 2013, 12:23 pm by reedlom »
