0 Members and 1 Guest are viewing this topic. Read 5156 times.
Not all tube give warmth. I am suprised the those n3s gives that kind of sound.
Thanks for all the input guys. I've got the N3S's up and running, they sound pretty good in 2.1 with the SVS sub. I wasn't aware there was a feature like HT bypass on some preamps. I've read a little bit about it, but I'm not entirely sure how it works. Currently my setup goes Ps3-->Marantz-->Power amp, with the Ps3 doing all the decoding, connected via HDMI. So how would this chain look with the inclusion of a HT bypass preamp?Jon
PS3-->Marantz-->Preamp-->Power ampHow does your system sound with the Marantz powering the speakers instead of the Emotiva? Emotiva amps aren't really known for their warmth. I have the SR6005 and use the internal amps to power my speakers. They sound pretty good.
I'd like to follow up on this. Currently I use the Audyssey processing in the Marantz receiver. It's nothing short of a miracle on the subwoofer in my living space, it's literally night and day difference. So could I still use this configuration for 2.1 listening, leaving the Audyssey processing on for the subwoofer?PS3--> Marantz (in bypass L/R mode) send L/R-->Preamp --> Power amp and just send the sub out to the sub.But if the PS3 is doing the decoding, what value does the preamp add here?
If you want tube sound in that set-up, I think that there are good hybrid amp options available. I really liked the Butler 2250 on my SP Tech Minis, which needed more power than I could afford in a tube design. There is a Butler 5150 for sale here now, that you might want to give some thought to. I am a big fan (no affiliation with seller)
You can check out reviews of the 2 channel Butler below: http://www.6moons.com/audioreviews/butler/2250.htmlSame amp modules, but the 5150 (= 5 channels @150W per channel) is less powerful than the 2250 (=2 channels @250W per channel).
How would the 2 channel Butler compare to the 2 channel Fetvalve 400R from Van Alstine? It has a little more power, any other differences?
I thought it would be reasonable to chime in here just to remind you that all AVA products, new or used, to come with a 30 day satisfaction guarantee.Thus there is no big risk to simply try one for yourself in your own system. If it does not do it for you, your only cost is shipping expense.Frank Van Alstine
