0 Members and 1 Guest are viewing this topic. Read 3215 times.
I would say just listen to them alot! The more you listen to them, the sooner they will be broken in!
Do NOT run your main equipment 24/7 to speed up "break in"You can do some serious damage to your components
I would expect that running round the clock at low volumes/power (< 60 dBC) shouldn't hurt anything - whether it "breaks in" a speaker or not. If a new speaker can't take that, then something is wrong.
Any speaker worth its salt should sound great out of the box. I have encountered a woofer or two that requires some flexing to smooth out the midbasss. But we're talking minutes--not hours or days. In most cases, companies that promote extended break-in periods are just stalling for time, hoping you won't ask for an immediate refund. And if you're thinking crossover components need extended play to break in, forgeddabouddit.
Wait, what, you don't think it's necessary to break in speaker cables, or interconnect cables, much less drivers and capacitors, for hundreds of hours?! Paul
