Speccing out options on a STSC
0 Members and 1 Guest are viewing this topic. Read 8260 times.
jsalk
    • Salk Signature Sound
Re: Speccing out options on a STSC
« Reply #40 on: 12 Mar 2013, 08:24 pm »
I'm considering the SCST in black satin with 3/4 bamboo, does it mean there will be no veneer and the bamboo would be dyed black?
Would you be able to see visually it was bamboo since it's black?
If you do an automotive finish, you will not see bamboo.  If we do a black dye over bamboo, you will see the bamboo close up.  But the grain in bamboo is on the subtle side.  So when you dye it black, it looks like a black speaker from a distance.  Only when you get quite close can you see a hint of bamboo grain in the finish.
I hope this answers the question.
- Jim
