Will a bit is 5 work well with a 4bsst amp?
0 Members and 1 Guest are viewing this topic. Read 1669 times.
jaxwired
« on: 6 Mar 2013, 01:38 pm »
Considering a bryston BIT.  Will the baby of the line work with my 4bsst2 amp?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Will a bit is 5 work well with a 4bsst amp?
« Reply #1 on: 6 Mar 2013, 01:58 pm »
HI
It will depend on the impedance of your speaker and the current draw needed for the levels you listen at.  The 4BSST2 can draw 7 amps at full power.
james
RLL1
« Reply #2 on: 6 Mar 2013, 07:44 pm »
HI
james
James
Is this determined using the formula "Amps = Watts / Volts"? If so, what wattage value are you using to get 7 amps?
Rick
« Reply #3 on: 6 Mar 2013, 07:53 pm »
James
Rick
Hi Rick,
It is just from the sheet that engineering supplied me.
james
srb
« Reply #4 on: 6 Mar 2013, 07:56 pm »
It would seem that if the 4BBSST consumes 2100W at full power per your spec sheet, that the current draw would be far greater than 7A at full power, closer to 17A with 120V line voltage.  I doubt that anyone would drive it to that level, but 7A seems too low.
Were they perhaps quoting output current?
« Reply #5 on: 6 Mar 2013, 08:07 pm »
I will check - maybe a typo (7) vs (17)???? :duh:
james
« Reply #6 on: 6 Mar 2013, 08:58 pm »
James
The 4B is rated at 300 Wpc. Generally, a Class AB amplifier is about 70% efficient at maximum power, so 2 X 300 W / .7 = roughly 860W. The idling power is about 125W, so 125 + 860 = 985W. That would require just over 7A from a 120V line, 120V X 7.143A = 985W.  If a spec sheet says 2100W it is a misprint.
cwr
srb
« Reply #7 on: 6 Mar 2013, 09:14 pm »
Quote from: cwr
Using the same exact calculations, the current draw at 500W/ch full power with a 4 ohm load would be ~ 13A.
I don't know what the efficiency of the Bryston amplifiers are, but 70% may be a bit optimistic, as some other A/B amplifiers are rated between 55% and 65% efficiency.  If it were 60%, the 4 ohm full load current would be ~ 16A.
werd
« Reply #8 on: 6 Mar 2013, 10:21 pm »
Get a bit 20 in 240. No such thing as overkill with amp in the 4b range and up. Trust me on that.
« Reply #9 on: 6 Mar 2013, 11:23 pm »
Yes, with both channels running at 500W each the circuit breaker would eventually open.  However, no musical signal would ever produce full sustained power, and circuit-breakers do allow for temporary overloads.
cwr
