Visual identification of different S&B TX102 versions
0 Members and 1 Guest are viewing this topic. Read 2322 times.
aleph
How do you visually identify whether you have the Mk  I, II or III versions of the copper TX-102's?
John Chapman
    • http://www.bentaudio.com
« Reply #1 on: 3 Jul 2004, 01:40 am »
Hello!
Unfortunately it is a bit cryptic... I am going to talk to s&b about marking these things....
If you have the lowest tap as 46db and 19 taps total then it is a MK I. A few MK II's also have only 19 taps but most all have 23 taps
If it was bought in the last few months it is a MK III
All else is MK II
I can tell right away when i measure them here but I know that only works if you have test gear!
Post a description of what you have and it's history and I'll get to the bottom of it for you.
Thansk!
John
aleph
« Reply #2 on: 3 Jul 2004, 06:56 am »
Hi,
I haven't got any. I was planning to check out someone who may have a unit and wanted to know how to verify what they were.
Your explanation will help a lot (you're right. no test gear here ;-).
Thank you.
