Anyone have specs for the Benz Ace L cartridge, not the new version but older..
0 Members and 1 Guest are viewing this topic. Read 1224 times.
starkiller
Have the older version of the Benz Ace L cart, serial number #29861, and through actions entirely of my own i need the VTF for it along with the weight so I can set the VTA...again.... :duh: :duh:
thanks!
SET Man
Hey!
   I have the first ACE version of the high output. According to the manual....
 Recommended tracking force: 1.7-2.0 grams
 Optimum tracking force: 1.7-1.8 grams.
    I track my at 1.8 grams. Beside the different in output I think tracking force is the same for the "L" also.
   Hope this help.
Take care,
Buddy :thumb:
starkiller
Thanks for the info!  You happen to know what the dimensions are so i can set the VTA?
« Last Edit: 4 Mar 2013, 08:57 am by starkiller »
SET Man
Hey!
    No dimension listed on the manual. But it does mention recommended VTA of 20 degrees.
    I don't have fancy microscope, so I did it by ears, listening to the detail in the high and etc. at the end it looks close to the recommended 20* and I can see the stylus is slightly leaning forward... not sure if it is perfect 92* but I'm sure is very close to that.
    This is something I don't want to do often because adjusting the VTA on my arm is a pain to with it's locking collar type with small Allen screw  :icon_lol: Well, I think it sounds fine now.
Take care,
Buddy  :thumb:
« Last Edit: 6 Mar 2013, 06:21 am by SET Man »
starkiller
Thanks for the help!
