sounds better without a Dac
0 Members and 1 Guest are viewing this topic. Read 1146 times.
brooklyn
« on: 4 Mar 2013, 02:47 am »
Okay, you people are going to think I’m nut’s but I had a short listening session with my audio system without a Dac and liked the way it sounded in some respects.
I decided to bring my PS Audio DL lll Dac with me to my apartment in Oklahoma to use with a headphone amp and hooked up my old Sony S7000 DVD direct to the preamp, I normally use the Sony as the transport in my main system
I put on, What’s New, by Linda Ronstadt and the Nelson Riddle Orchestra, I heard Linda singing to me as I sat there with my mouth open, HEY, I’m not kidding.
Her voice was all around me and it sounded more like a live performance. I listened to the whole album and had it cranking. The Dac seems to make the music a little softer in the top end, I gained that raw sound quality in the top end without the edginess which makes it sound live to me.
Maybe I’m using the wrong Dac for my system, all I know is that it sounded petty darn good without it.
So what do you think, am I nut’s or deaf.
« Last Edit: 4 Mar 2013, 04:49 am by brooklyn »
Napalm
Re: sounds better without a Dac
« Reply #1 on: 4 Mar 2013, 03:16 am »
You're doing fine.
sl_1800
« Reply #2 on: 4 Mar 2013, 03:28 am »
I once had one of those Sony players and it's not a bad sounding player.
SET Man
« Reply #3 on: 4 Mar 2013, 03:37 am »
Hey!
   No, you are fine. :D
    Newer, more expensive, more complicated don't always mean it will sound better in your system. :D
    If it sounds better to you than just enjoy it.
Take care,
Buddy :thumb:
S Clark
« Reply #4 on: 4 Mar 2013, 04:22 am »
Maybe both.  So what.  If it sounds good to you, to hell with the rest.
