3D/HDMI Problem with SP3
0 Members and 1 Guest are viewing this topic. Read 1233 times.
Boldlygo
« on: 3 Mar 2013, 10:32 pm »
Well everyone, I just received my new Bryston SP3. Whoohooo!
 Having many trials & tribulations setting inputs - I'll work through it, but this is definitely NOT user friendly. This remote is just plain awful. Who puts 4 arrow keys in a straight line?! Can't wait to get a universal remote. (Just picked up the Logitech Harmony 900)
 I did some testing for sound and here's what I can report:
 I use a computer I built as a music server running iTunes with everything ripped using AIFF. One of the reasons for getting the SP3 was to eliminate other pieces, such as my Ayre K-3x pre, my Marantz AV-7005 and my NAD M-51. Well, this piece does the job of all of those and better. Great, great sound detail and presence in 2-ch and multi-ch sound.
 I had the use of a Stello U3 piece and tested the USB out of the computer into the Stello, then into the SP3 using a Coax cable and an AES cable. Sounded pretty good. But then I plugged the USB cable directly into the SP3 and it was just as good, so no need for the Stello. Then, I plugged my trusty Chord optical cable from the PC to the SP3 and it sounded even better! So this is the configuration I'm going to stick with. The optical connection is the best sound I get. (I may have said this before in a previous post, but using the music server blows the doors off playing the CDs directly from any player I have ever tried).
 I have discovered one major flaw though - I was trying to play a 3D movie from my OPPO BDP-103 today to my Epson Pro Cinema 6010 through the Bryston and it kept saying I didn't have a 3D display hooked up. Well I actually have 2 displays hooked up - a Sanyo HDTV 42" 2D display and the Epson. Unless I disconnect the 2D from the back of the Bryston (in HMDI 2 out) I cannot play 3D movies. Not good! I think Bryston should have made the HDMI outputs selectable to run in either parallel mode or independent mode and allow you to switch between the 2 outputs. It's not good having to unplug a cable every time to watch 3D. Is there another way to do this that I can't figure out other than adding an HDMI switcher to a system that should be able to do this?
Buseto
Re: 3D/HDMI Problem with SP3
« Reply #1 on: 5 Mar 2013, 12:25 pm »
I think you would have more success when you would put your question in the SP3 threat.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 5 Mar 2013, 12:43 pm »
Sorry just saw this - will get Stan to comment.
james
« Reply #3 on: 5 Mar 2013, 03:33 pm »
From Engineering
I will have to ask MDS if it is possible to temporary disable one of the HDMI outputs or even better, fake video EDID to force 3D through.  Either way it would need some kind of a user control/screen/web interface to manipulate this setting.  It could als be too much complexity needed for some rarely used feature.    Perhaps a better solution would be to use an external HDMI switch?
Stan
Boldlygo
« Reply #4 on: 5 Mar 2013, 11:13 pm »
I've thought of that - but one of the main reasons to get my Bryston was to eliminate extra boxes. I understand where you're coming from - programming, etc. Maybe in a future firmware update?
I can't see how this could be a rarely used feature, unless I'm the only one with a 2D & 3D plugged in at the same time? I mean, there are 2 HDMI outs, so I thought this would be a common setup. Oh well. I'd hate to have to get something external. Let me know. I look forward to hearing from you!
