Diod/LED lamp to NC400
0 Members and 1 Guest are viewing this topic. Read 3808 times.
mangew
« on: 3 Mar 2013, 11:25 am »
How do i connect an diod/led (power on indicator) on front panel?
I will use a power on switch on the backpanel but want something that tells me the amplifier is turned on on the front.
There are some power on switches with led indicators built in to buy but i would prefer a smaller one.
ufokillerz
Re: Diod/LED lamp to NC400
« Reply #1 on: 3 Mar 2013, 10:49 pm »
There is a aux power out, it is 21v when on 220voltage and 42v on 110voltage
Connector J1 on the SMPS power supply. i think that would be the way to go to hook up a led
then again i never did get one hooked p.
mangew
« Reply #2 on: 4 Mar 2013, 07:08 am »
Ok, anyone has a wiring diagram?
Its something like this  i want:
http://www.avx.hu/forum/uploads/post-32-1195054349.jpg
Julf
  • Grumpy second cousin of Mark V Shaney
ru1020
« Reply #4 on: 26 Nov 2013, 09:18 pm »
I used a fibre optical (toslink) cable to get the light from the LEDs of the amps to the front panel. All you have to do is take the plastic cases of the toslink cable. there is a little metallic connector with a lens under the plastic plug which fits nicely into the front panel through a 2.5 mm hole
jtwrace
    • TIPP YouTube Channel
« Reply #5 on: 26 Nov 2013, 09:45 pm »
It would be nice if you could post some pics of what you have done.   :thumb:
ru1020
« Reply #6 on: 26 Nov 2013, 10:03 pm »
I'm on holidays with only an iphone. there is a topic on diyaudio with pics.. as this is my first post here, I'm not sure I can link to it
jtwrace
« Reply #7 on: 26 Nov 2013, 10:04 pm »
I'm on holidays with only an iphone. there is a topic on diyaudio with pics.. as this is my first list I'm not sure I can link to it
Well, when you can, please post pics here.   ;)
ru1020
« Reply #8 on: 28 Nov 2013, 09:59 pm »
here goes. Will post some more images of the finished amp..
removal of the plastic protection
one end over the LED on the amp
With this cable, I could use the outer insulation to fit the cable over the LED
the other end has the light. You can drill a 2.5mm hole through the front panel. The light is discreet but very visible
