Hi Jens,
How much noise are you hearing from your 55w AKSAs? My speakers are 94db, and the buzz and hum I get are audible only within 20-30cm of the drivers; it is absolutely inaudible at 2-3 meters.
Can you put a shorting plug on the AKSA amp inputs? (shorting plug = RCA with a resistor soldered across hot and ground, resistance value somewhere around 50-200 ohms... I'm not sure why a total short would be a problem here though, but gurus usually recommend some small R>0)
so back to the amp... with a shorting plug in place (thus eliminating any noise from sources, preamps, interconnects, etc.) you are left with the possibility of noise from the amp itself, EMI from the surroundings, and/or noisy mains.
If you are certain that your amp is noisy, consider the following:
- lightly twisted signal leads, short and well away from AC. You could also try some good coax here, but I'd see that as a near last resort
- experiment with running a wire (or not) from Single Point Ground to chassis ground... one configuration may be quieter
- keep torroidal transformers seperated from the AKSA amp boards
- look for poor solder connections (I use an illuminated magnifying glass, mounted to my workbench, to be sure that all solder joints look good). Bad solder joints, however, usually sound distorted or harsh... but I suppose that a bad solder joint in the signal ground could lead to buzz or hum...
If these simple ideas don't solve the problem, post back and Hugh + the high gurus here will help with some more ideas. I've been reading "AKSA posts" since nearly the beginning, and I can't remember many (any at all?) "noisy amp" posts.
Good luck,
Peter
