Need to raise a Garrard 301 5mm higher than its plinth
0 Members and 1 Guest are viewing this topic. Read 1989 times.
efhjr
  • Why, why, why, why are we sleeping?
I need a way to raise a Garrard 301 turntable 5mm from its plinth (to accomodate a custom tonearm collar), and would like to use something made out of grungebuster.
My idea is to use washers on the four chassis screws -- the turntable uses 6mm ID/16mm OD washers.  Would two grungebuster washers and one PTFE washer per chassis screw do the trick? Do you have a better suggestion?
Herbie
    • Herbie's Audio Lab
Re: Need to raise a Garrard 301 5mm higher than its plinth
« Reply #1 on: 2 Mar 2013, 10:13 pm »
Hi, efhjr. We have lots of customers using grungebuster Washers and Extra-Thick grungebuster Washers with applications like this. Two regular grungebuster Washers and a PTFE washer would give you only 3.6mm thickness, though. Three regular grungebuster washers (1.6mm thick each) and a PTFE washer (.4mm) would give you a thickness of 5.2mm, which would compress to about 5mm. (Likewise, one Extra-Thick grungebuster Washer (3.2mm thick), one regular, and one PTFE would give you 5.2mm thickness.)
Steve Herbelin
Herbie's Audio Lab
« Last Edit: 3 Mar 2013, 12:32 am by Herbie »
