FS: Jolida JD 1501BRC Hybrid Integrated Amp - SOLD!
0 Members and 1 Guest are viewing this topic. Read 1293 times.
RPM123
This is the new BRC version with XLR inputs and a mini iPOD front panel input. The 1501RC is a remote controlled Hybrid design with 12AX7 tubes in the preamp driving a MOSFET solid state output amplifier stage. The amp has a set of preamp outs as well as a set of fixed tape outs. Full function remote control. IEC removable power cord.  SOLD on the goN!
This is a very impressive sounding amp! I have been using it with a pair of Devore Nines for several months, however, I am going back to my separate component phase, hence the sale. Unit has performed flawlessly. Like new condition. Shipping to lower 48 included at asking price - $635. Comes with beefy remote, box, manual and power cord. AudiogoN feedback under Grk.
Construction Details and Features:
Fully Integrated Stereo Amplifier: Input 500mV driving 100 watts
Remote Control
Multiple Inputs: Front mounted selector switch-Input(MP3), XLR, CD, DVD, and Aux. (for TV, VCR or Computer)
State of the Art Components: ALPS audio potentiometer, gold plated RCA input jacks.
Technical Specifications:
Rated Output Power: 100 W per channel at 8 ohms, 22Hz to 19KHz
175 W per channel at 4 ohms, 22Hz to 19 hz
Frequency Response: (at 1 watt into 8 ohms) 5Hz to 100KHz + 1dB
Bandwidth: 22Hz to 19kHz + 3dB; 0dB 100 W 1KHz
Distortion THD: Less than 0.1% at 90 W output, 22Hz to 18KHz
Input Impedance: 47Kohms
Input Sensitivity: 500mV at 1KHz and 8 ohms for 100 watt output
Noise and Hum: 90dB below rated output
Tube Complement: 2 pcs. 12AX7 for the preamplifier
Power Requirements: 110V-120 VAC 60Hz 180 watts-standby, 450 watts maximum (220 VAC 50Hz option)
Dimensions: 17 inches wide by 13 inches deep by 4.5 inches high
Shipping weight: 38 lbs
« Last Edit: 9 Mar 2013, 06:22 pm by RPM123 »
RPM123
Re: FS: Jolida JD 1501BRC Hybrid Integrated Amp -$635
« Reply #1 on: 9 Mar 2013, 04:14 pm »
BUMP - lower price!  :D SOLD on the goN. Sometimes, I wonder why I even bother listing here. Must be because it's free.
« Last Edit: 9 Mar 2013, 06:27 pm by RPM123 »
