FS: Simaudio Moon LP3 Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 1625 times.
fz1jmp
« on: 2 Mar 2013, 01:57 am »
This is an excellent phono preamp that performs well above its low price! This unit has received excellent reviews. It is in very good shape, i would say 8/10. I have a copy of the manual, original box and original power. It's the little brother of the LP5.3.
Here is some info from the Simaudio website:
· End-user adjustable impedance loading (100Ω and 47kΩ)
· End-user adjustable capacitance loading (0pF and 100pF)
· End-user adjustable gain for moving magnet (40dB) & moving coil cartridges (60dB)
· Two-layer PCB tracings using pure copper for low impedance characteristics. The advantages include better circuit layouts resulting in a much shorter signal path and a vastly improved signal-to-noise ratio
· Inductive DC Filtering for a significantly lower noise floor
· Accurate matching of military-grade components with ultra-tight tolerances using surface-mount technology for extremely short signal paths
· Compact, rigid all-aluminum chassis with gold-plated RCA connec
Asking $300 plus shipping. I will cover PayPal fee. Thanks for looking.
Jack
« Last Edit: 3 Mar 2013, 03:10 am by fz1jmp »
