0 Members and 1 Guest are viewing this topic. Read 8794 times.
It is good that everything fixed. I could not agree more - Jim is the Man. So, do you ever think about adding center speaker to your system? The SS8c is expensive but well worth the price if you are into multi channel music. Just my 2cts
Boy is that a relief. Jim e-mailed me several times asking about the impedance curve, any thoughts I might have, and my reactions to the video-audio clips of the mystery sounds. All I could tell Jim was that it sounded like a pareamp overload issue. I guess it was actually the preamp overloading the amp, but I'm sure glad I don't have to go back to the drawing board on the SS8.
That is a great example of how customer service *can* be done well. Just to clarify, it was the BluRay overloading the preamp, which was then sending a clipped waveform to the amp? I assume then, the lights on the amp were detecting the already clipped audio. This should have been audible at fairly low volumes, correct?
You should tell Oppo your experience. It's bothersome that the default volume control setting on the Oppo would cause this.I'm also thrilled you have this worked out.
Using the analog outs: "Output Level: 2.1 Vrms (RCA) or 4.2 Vrms (XLR) at 0dBFS"
I know I am late to the party on this thread but I am considering an OPPO 105 > Cary SLP-03 > Bryston 4B3 combo and wondering if you still enjoy this setup? Is there enough gain using the fully balanced connections?
It's a Bryston 4B3. I am willing to bet money on you never turning the volume dial over 30%. After that 30% point your neighbors will start throwing rocks at you.
Very true, my query was more about going fully balanced...would I have to use the gain switch on the back in this combo. I will also say my Vandersteens eat up power and I've been able to hit 50% volume at times...no idea why the police haven't stopped by yet
