0 Members and 1 Guest are viewing this topic. Read 18461 times.
If you have this kind of money to spend, you should really go and listen to loads of gear. It’s a lot of money to spend and get it wrong because someone else says they like it.
Sure, it's just that there's way to much gear to audition everything, so I thought I could get a starting point, some stuff to put on the audition list, by hearing what folks love about their own gear or stuff they've heard. Speakers will require the most listening, of course. And I have a few on my list to audition already. Just thought it would be fun to see what people recommend, and why. Mostly why, in fact.
What's your room like, big or small, square or long and narrow?Everything hinges on your room.
Serenity Acoustics Super 7 10,000 open priceMac Mini Loaded 1000New Hi Rez dB Audio Labs Dac (Guess 2K)Cables 1kOppo 105 Modded 1500Two Sealed subs for corners 2000Dodd Preamp 2000Oyen Hard Drive FW 350FirstWatt F5 200022K Im good....
First step would be to break it down into components, and budget amount for each. Do you want a turntable setup or not? What sources do you want? Many people these days are doing 100% computer audio, if you wanted to go that route it would leave more money for things like speakers and amp. I'd also say consider your room and what treatments it needs. $25K is enough you can get a pretty killer setup if you shop smart ... not enough to be crazy and make it rain. What are your personal preferences? What speakers have you heard that you really liked? How would you define the type of sound you're after?
Don't exactly know yet, as it'll be in a different house. But I'll be looking with an eye toward a suitable dedicated room. So figure large bedroom-sized (say, 14'X18'), rectangular, and sealed. Will be well-treated with absorbers and diffraction and bass traps. Carpet or big area rug, heavy drapes over windows. Total placement freedom, furnished with bookshelves, a desk behind the listening position, and a comfy sofa in the prime spot where I can sit for critical listening, and work on a laptop on a lap-desk for general low-volume background music.
I don't have any specific recommendations but the delmaination problem with the Manepans is a thing of the past.UV and humidity was breaking down the earlier brands of adhesives.
DAC (preferably with excellent USB implementation)PreAmp(s)Speakers (and subs if necessary)Budget covers the above only. Front end is Macbook pro, ART Legato for 16/44.1 material. No TT. Maybe an Oppo player later. Haven't heard many high-end speakers yet. Love the Maggie sound, but have only heard the MMG and Mg-12 to date. Running LSA-1 signature monitors and a Salk Songsub in my living room. Great sound for the money, and will stay in that system. Didn't like the Linn, Sonus Faber, or Paradigm stuff I heard, though admittedly, it was all low t mid in their lines. PSB has possibilities. Looking for smooth and refined and transparent/neutral that can still rock. Gear, I'm in the same boat. Running Emotiva stuff in the living room. It's okay, and great for the money. My current DAC is a Van Alstine Ultra, fed by the Legato, and it's very nice. His FET-Valve stuff is on my list, but will have to be very impressive, as I'd rather go SS with this setup. I'm talking about something I'll be happy with for the next 20 years, so am aiming high, obviously. Have heard Anthem and NAD gear, and Parasound extensively, but the same applies; low in their lines, except for the NAD stuff, of which I've heard both upper and lower end. I could live with any of them, especially if it only gets better going up the line. Got a lot of listening to do over the next year, and like I said, some kind of starting reference point for what to audition would be helpful. Speakers on my to-hear list include Salk and Dynaudio, and the Magnepan 3.7 (20s are maybe just too big), though I have reservations about their longevity, the word "delamination" occurring too often in internet searches for my taste.
If I had your budget, I would start with used Vandersteen 5A's and go from there. Go out of your way to demo a pair. Have fun,Jerry
