Sealing box edges before paint?
0 Members and 1 Guest are viewing this topic. Read 1532 times.
mclsound
« on: 25 Feb 2013, 03:22 pm »
Hi Guys
What have you found to be the best meathod of sealing butt joints for both MDF and Baltic Birch before taking the cabinet to the paint booth?
thanks.
Sorry if this has been explained before
john
decal
Re: Sealing box edges before paint?
« Reply #1 on: 25 Feb 2013, 03:54 pm »
Body filler (Bondo) works quite well.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« Reply #2 on: 25 Feb 2013, 03:58 pm »
Hi Guys
thanks.
john
Bondo will just cover, not seal.  Seal first, use something like Lacquer Sanding Sealer.  It soaks in pretty well, and after 2-3 coats will make the MDF pretty much moisture proof.  After that skim coat with something like Bondo, or Marine Epoxy with a filleting filler, or fiberglass.
Napalm
« Reply #3 on: 25 Feb 2013, 04:10 pm »
I believe it depends on the solvent that the paint uses. Mismatch sealant and paint and either the sealant won't seal or the paint won't adhere.
mclsound
« Reply #4 on: 25 Feb 2013, 05:11 pm »
so find out the paint and primer...He is an amazing automotive custom painter so definately automotive.
WireNut
« Reply #5 on: 25 Feb 2013, 05:33 pm »
West system epoxy with the 404 or 406 filler will fill all gaps/voids, seals and makes the joint rock solid, then finish off with bondo / filler glaze as needed. I get mine from Rockler.
Jim Griffin
« Reply #6 on: 26 Feb 2013, 02:44 am »
There is a recent thread on Parts Express Tech Talk that talks about Duratex and some discussion of edge coverage is included.  Read this:
http://techtalk.parts-express.com/showthread.php?236136-Duratex-and-MDF-finishing-questions
Jim
mclsound
« Reply #7 on: 3 Mar 2013, 10:48 am »
thanks
