Setting up subs with DSPEAKER 8033s
0 Members and 1 Guest are viewing this topic. Read 988 times.
jaylevine
« on: 25 Feb 2013, 03:17 pm »
Hi,
I'm running two Rel Strata III sub-woofers from my DSPEAKER 8033s unit. Does anyone know if you must first set the desired  roll off frequency for each sub-woofer prior to running the auto-calibration mode? Or can I change the roll-off frequency on the subs after I run the calibration without having to re calibrate the unit again?
Jay
rodge827
Re: Setting up subs with DSPEAKER 8033s
« Reply #1 on: 25 Feb 2013, 03:51 pm »
Hi Jay,
Dspeaker wants you to deactivate or bypass any crossover on the sub and run them full range.
After the calibration you can then adjust where you want the crossover.
http://www.dspeaker.com/fileadmin/datasheets/dspeaker/antimode8033CSen.pdf
Chris
jaylevine
« Reply #2 on: 25 Feb 2013, 03:55 pm »
Thanks. I wasn't able to find the manual at home and should have thought to look on-line ( :duh:)
