0 Members and 1 Guest are viewing this topic. Read 2403 times.
Paul, I assume you've heard from Alan by now? If not I have a hard copy I can scan.vv - your question is a bit confusing.... could you elaborate a bit more?
I thought i could pass a USB flac files to these DEQX and make it act as a DAC for my music server....if it it able to take USB signal if it is not able to take USB signal can i use a USB to SPDIF converter and pass the songs DEQX....
Hi, the current HDP-4 accepts USB I believe, the earlier models would need a USB-SPDIF convertor. However, the DEQX is a crossover/EQ, using it just as a DAC would not really make sense - ?
here you go.
