Replacing an Outlaw 950 pre/pro with a Denon AVR-3805
0 Members and 1 Guest are viewing this topic. Read 3121 times.
zybar
I am only interested in both units for pure HT (no 2 channel).  If I went with the Denon, I would not be using the amps (unless I find it good enough to drive my 4 surround speakers).
On the surface, the Denon has tons more features than the Outlaw.
I am in the process of selling my old Denon AVR-4800 and I always thought it was a very nice sounding unit (better than similarly priced units from Rotel, Adcom, etc...)
George
Woodsea
« Reply #1 on: 1 Jul 2004, 12:54 pm »
The 950 is older.  But would hope be cleaner.  You may want to try out the outlaw saloon for a references to comparisons.  I had one on order before they came out.  I ended up getting the Harman Kardon, though.  Not much patience and alot easier on the pocket book.
Why Denon and not Pioneer or maybe even all digital like Panasonic or H/K?  Just wondering.
John Casler
« Reply #2 on: 1 Jul 2004, 03:16 pm »
George,
In that price range (Lists for $1499) I have been using the Sherwood Newcastle P965.
It has all of the most used processes (excepty THX) and many quality features too.
Marbles
« Reply #3 on: 1 Jul 2004, 03:25 pm »
George, did you find your 4800 could drive your surround speakers?
I would think that it could.  If the 4800 would, I would think most midpriced units, like the one you are interested in could as well.
zybar
« Reply #4 on: 1 Jul 2004, 03:53 pm »
Never tried the 4800 in the main HT system.
It was in the secondary livingroom system hooked up to Reynaud Twins.
I am sure the 4800 has more than enough power for the 4 surrounds.
Using that logic...I could also sell my Sherbourn 5 channel amp.  I use my 2 channel amps to drive the L/R when using the HT.
So now the question is:
Is a $2K list current receiver better as a pre/pro and drving just the surrounds than the Outlaw 950 + Sherbourn?   :?:
George
Marbles
« Reply #5 on: 1 Jul 2004, 04:09 pm »
Quote from: zybar
George
I don't think you would notice the difference in amps between a  receiver or the Sherbourn for the surrounds, so the question to me would be "is a $2K list current receiver better as a pre/pro than the Outlaw 950?"
I would say almost certainly yes for some specific receivers, like the Sherwood Newcastle P965 that John recommended, the Pioneer Elites, and the Denons.
zybar
« Reply #6 on: 1 Jul 2004, 04:21 pm »
John,
I know the Sherwood doesn't have the room correction that the newer Denon units have (which is a potential big reason for going with a change), do you know if it allows you to set the distance from each speaker?  Can the bass crossover be set for individually for each speaker?
George
John Casler
« Reply #7 on: 1 Jul 2004, 05:11 pm »
Quote from: zybar
John,
George
No, it doesn't but, it is upgradable and I think a thread on AVS has a few questions about that.
It does have speaker distances (except the sub)
Bass is global.
Another suggestion is the Yamaha.  A client of mine with a brand new full VMPS system has the RXZ9.
I have to be honest, I never really liked Yammies "sound", but this one is incredible.  Even the amps are of great sound quality.
But the "set up" and equalization system/GUI/adjustments is the best I have seen.
I beleive the model below it, the RXV2400 has 90% of the bells and whistles at a retail list of $999.
Might too be worth a look and listen.
jgubman
« Reply #8 on: 1 Jul 2004, 05:19 pm »
George, I've read very mixed reviews of Denon's implementation of "room correction". They actually EQ the entire frequency range, rather than just the sub 200Hz range.
This review:
http://www.audioholics.com/productreviews/avhardware/Denon-AVR3805_review07.php
is not exactly glowing: the reviewer wound up not using it in his reference system!
Personally, if you're really concerned about EQ, I'd look toward the Krell showcase (~$2,500 used) or maybe a B&K ref 50 (or 30 if you don't care about 7.1). Of course if you can swing the $10k, a meridian or the new Lexicon mc-12 will definately get you where you want to be!
I personally haven't listened to the effects of the EQ in any of the above processors, so take it for what it's worth (not much...).
zybar
« Reply #9 on: 11 Jul 2004, 03:08 pm »
I took the plunge and will have a Denon 3805 here on Monday/Tuesday.
At the price I am getting it at, if I don't think it is better than the Outlaw, I will just sell it and keep the Outlaw.
George
jgubman
« Reply #10 on: 11 Jul 2004, 05:13 pm »
Cool, let us know how it works out and what you think of the room correction.
zybar
« Reply #11 on: 15 Jul 2004, 02:19 am »
Picked up the receiver today from my dealer.  Here are a few pics...
I plan on putting it into the system tomorrow.  I don't know how much time I will have to learn the room correction, but it needs to be up and running so I can lend a friend my Sherbourn 5/1500A to power his RM 30's while his EAD is busted...
Will post after some break in and I learn the ropes.
George
