0 Members and 1 Guest are viewing this topic. Read 4508 times.
I have both the Benchmark USB Dac1 and the Schiit Audio Bifrost Dac.The Bifrost is a simple, great sounding neutral Dac that gives85% of the performance as the Benchmark at 1/3 the price. You can get itwith USB for under your budget. Rave reviews on this made in USA Dac.
He does not need USB, but thanks for the post.
* Parasound Z DAC ($449, online Audio Advisor has great 30 day policy). A buddy has one on trial and LOVES it
+1 my Z-Dac is fantastic. Be sure to look at the silver model in lieu of the black.
Thanks for the responses and the suggestion of the zdac. (yet another DAC to consider! ) At any rate, since the zdac has been suggested, I feel compelled to raise another question, although I prefer not to as it appears to be highly debated according to what I have read. Well, here it goes, does a non oversampling dac provide any sonic benefits over dacs that oversample or upsample, or is it merely a listener's preference? I ask because both the Havana and the Dac-it have been described as "organic" and 'Natural," and less digital, which I have attributed to their NOS configuration.
Mark,Yes, the DAC category has no home but here. But that's ok cuz for $500 you can have HiRez all you want!! I'd look at:* Parasound Z DAC ($449, online Audio Advisor has great 30 day policy). A buddy has one on trial and LOVES it* (the tiny new Audioquest and Meridian DACs are $300-ish but USB only, so no go for you specifically cuz you need coax/toslink for your source)The ones you list are good candidates too. Lemme think more on this....
The Z-Dac looks good, but for me the USB only going to 96k took it off my list. The SPDIF connections are 192k.
I know this is a hi-rez circle, and my quesiton pertains to some DAC's which are not hi-rez, but for the lack of a more appropriate digital circle, here is my thread. I am looking to add a DAC to my system, which includes a Musical Fidelty A5 cd player, and from time to time, my ipod. I have been considering the following DAC's: MHDT Havana, Peachtree Dac-it, Musical Fidelity M1, Rega DAC, and the Channel Islands VDA-2. Out of these, I am most intrigued by what I have read about the Havana and the Dac-it. I am looking to buy used, so anything up to $550 is about where my budget is.The rest of my system includes Nola Viper IIa speakers, Emotiva UPA-1 mono-blocks, and (arriving today, finally!) Dehavilland Ultraverve 3 preamp.Any thoughts on these DAC's, good, bad or otherwise? Thanks.Mark
Again...if USB was an issue here I would NOT have recommended the Z for his under-$500 choice, I would have recommended the Meridian...but the OP has no use currently for USB. he has a cd player as a source.
I know that only way to know for sure is to compare the DAC's, but am I making a mistake to think that a new entry level budget DAC can outperform the DAC in my cd player?
