Can I make the OPPO 103 work with the BDP2?
0 Members and 1 Guest are viewing this topic. Read 1318 times.
Blueshirt1
« on: 21 Feb 2013, 02:50 am »
So here is the deal. I have been converting all of my CD to FLAC and buying highrez music and storing them on a WD NAS.  I am planning on getting a BDP2 but have yet to decide on which DAC. Let me put it another way, I am dying to get a BDP2 but with no DAC it is worthless to me. I'm leaning towards the Calyx Femto DAC but money for that is an issue right now.
So, maybe I am crazy, but I though well I do want a new SACD player so maybe I could use the OPPO 103 for the time being until I get a real DAC with the BDP2. And then when I do get a DAC I have a new Blu Ray player.
Not sure how the connections would work. Or if I would need an external screen to operate the OPPO.  I'm very lost at this point at what my best option is. Any help would be greatly appreciated.
ttsto
Re: Can I make the OPPO 103 work with the BDP2?
« Reply #1 on: 21 Feb 2013, 02:14 pm »
I doubt you can make BDP work with Oppo 103
BDP is a digital player:
 - will read the files from USB attached storage or from NAS
 - will output digital signal to be converted by a DAC
Oppo 103 doesn't have any digital input for external players (coaxial or USB). Oppo 105 will have those inputs.
brucek
« Reply #2 on: 21 Feb 2013, 02:23 pm »
Do you not have an audio receiver or processor that you're presently using in your system?
If so, it will have a digital input you can use.
adol290
« Reply #3 on: 21 Feb 2013, 02:33 pm »
The cheapest easiest way would to buy a BNC/RCA cable and go from the BDP-2 to your pre-amp or amp,
If you have a pre-amp or amp.
The cable is cheap and available here $19.00 for a 6 foot.
http://www.bluejeanscable.com/store/digital-audio/index.htm
I have the oppo 103 and have plugged in a USB drive, and played flac files.
The 103 was using the HDMI output into to my pre/amp. It's ok, but not as good as
 the BDP-2 - bnc/rca into my pre-amp.
If you do not have a pre-amp or amp,
when the BDP-2 firmware allows you to output on USB,
 you MAY be able to go USB from the BDP-2 to the oppo USB input, then out to ?
 I would not use it in this scenario.
Blueshirt1
« Reply #4 on: 21 Feb 2013, 02:47 pm »
Thanks all.
I have the Ars Sonum Filiomania Preamp/amp and it does not have those connection.
So looks like I need to go down another rabbit hole  :(
So has that been decided? I asked the question if that was a direction they were going but never got a response.
adol290
« Reply #5 on: 21 Feb 2013, 03:04 pm »
Are you saying your Ars Sonum Filiomania Preamp/amp does not have a RCA DIGITAL Input?
As for USB out on the BDP-2
http://www.audiocircle.com/index.php?topic=110296.220
James answered in post 223
srb
« Reply #6 on: 21 Feb 2013, 03:23 pm »
The Ars-Sonum Filarmonia is an integrated tube amplifier and has no DAC.
Blueshirt1
« Reply #7 on: 21 Feb 2013, 05:24 pm »
Correct SRB, so going BDP to Ars Sonum wont work.
I think I just have to give up on SACD and the OPPO and save my pennies for the real DAC.
Great news about the USB output on the BDP2. Supposedly its a superior connection on the Clayx Femto.
Thanks all.
