Custom CD Player $35
0 Members and 1 Guest are viewing this topic. Read 745 times.
Haoleb
« on: 20 Feb 2013, 05:13 pm »
Custom made CD player designed for use on a desktop to give that sleek and elegant look of wood mixing old and new technologies! This uses a Plextor cd-rom drive which are known for their quality and has a seperate power supply unit which uses a computer power supply. You simply need to make a cable consisting of two male IEC cable ends to interconnect the cd drive to the power supply and then another seperate IEC power cable to connect the power supply to the 120v outlet and you're good to go!
This has stereo RCA output jacks that are wired in directly to the drive's output. Also has a front headphone output with volume control. Power supply tested and works, Havent powered up the drive because I do not have the interconnect cable anymore which you need to custom make but it worked last time I used this thing. Power supply features a power switch with blue LED indicator light on the front. Features copper accent pieces on both the power supply unit and the cd player unit. Please ask any questions. Sold AS-IS. If you are looking for a one of a kind statement piece then this is IT!
Shipping is flat rate $25.00. See photos for more complete description. Please be aware that if you plug 120v power into the cd player unit or the top IEC jack on the power supply unit you will fry something. I should have used a different type of plug.. Just be mindful when making your connections.
