Which kits/s[eakers are most efficient
0 Members and 1 Guest are viewing this topic. Read 1857 times.
xecluded
« on: 18 Feb 2013, 05:33 am »
I want to try GR research speakers and looking for something that is more high efficient (no OB) for a tube amp.  Please advise.  Thanks
persisting1
Re: Which kits/s[eakers are most efficient
« Reply #1 on: 18 Feb 2013, 08:06 am »
I think you'll be happy with the N3 or the N3S kits. I've never heard them, but I've read and have been told good things.
I've owned Danny's OB and other sealed speakers he's designed.
persisting1
« Reply #2 on: 18 Feb 2013, 08:11 am »
Not sure of your price range or the availability of the drivers, but this might work for you.
http://www.audiocircle.com/index.php?topic=93720.0
Danny Richie
« Reply #3 on: 18 Feb 2013, 07:25 pm »
N3's are at 91db sensitivity.
I still have one set of drivers for the V-1 kit. It is basically a Super-V with the next P-Audio coaxial down from it. 97db sensitivity. It is an open baffle design though.
xecluded
« Reply #4 on: 19 Feb 2013, 04:12 am »
Thanks - i will learn more about the N3
Oscillate
« Reply #5 on: 19 Feb 2013, 06:01 am »
'Well as long as we're on the subject...
Danny, what is the efficiency of the X-series speaker
line (ie X-LS Encore, X-CS Encore, X-Omni, ect...)?
Danny Richie
« Reply #6 on: 19 Feb 2013, 02:10 pm »
X-MTM, X-CS, X-Voce, and X-Statik are all right at the 91db sensitivity range.
