0 Members and 1 Guest are viewing this topic. Read 21370 times.
This may be a stupid one.If you look at the topology of Felix the filtering cap before CMC are actually common to power supply line( they all are parallel to live and neutral ). If they are all parallel why there is a need for a capacitor bank before each CMC. There can be one bank of 1,0.1 and 0.01 uf common to all CMC and still work the same.Have anyone tried using a huge Felix with all this pre CMC banks in one unit (which will all together form a huge bank of filter caps) and found better than one with just one single bank of caps before CMC?
That's a different leakage! This is the intended current flowing through the capacitor in the normal way that capacitors work (they pass AC current). This is filter or circuit leakage.On line to line caps, Mr. Ott writes:Because this cap is not connected to ground, its value is not limited by leakage requirements. Typical values for this cap range from 0.1 uF to 2 uF. For safety reasons, a resistor, typically 1 Mohm is sometimes added in parallel with the cap. This resistor is used to discharge the caps when power is removed.You should read his book.
No current flows through a capacitor. By definition they store current [...]
