0 Members and 1 Guest are viewing this topic. Read 6125 times.
Dear Jax,Seem to remember that you used to have PMC speakers, thought you had a video on that - but may be wrong, what made you choose the Dynaudio speakers.Cheers,Bob
What do you think about Placette's passive?
Took a little excursion with a few other brands, but back with Bryston now. 4bsst2 in da house...
I buy CDs and rip them to iTunes in lossless format. Those are streamed to my airport express over hard wired Ethernet. That signal is fed as a digital stream to my benchmark DAC (which is also my preamp).
Thanks--So, it's wireless to the benchmark? Can you do hi resolution files that way?
You could add a Mac Mini on your table, have your music on that and control it with for instance an iPad. (you only need a screen the first time you set it up) Then you "avoid" wifi and can wire it directly to the Benchmark.
Nice looking system. Something you might consider trying with that dac into the amp. Try and find a TPV passive pre amp for audition. Set the pre amp volume on full and use the volume on the dac to adjust. Like that you get the sound of the dac straight into the amp with a buffered impedance. It will tightened up your soundstage with better bass response. You also get an excellent isolation between the dac and amp for noise. I have and Audio oasis TPV but Bent audio on this site makes them too.
Jax, I am thinking of the exact same amp and the benchmark dac. How would you describe the sound? Also what is the limitation if any of using the dac as the preamp? Would you consider adding a phono stage to this setup IF you played vinyl at all? thansk tony
Bryston and Dynaudio is pure ecstasy. Jax, i have the same speaker, just with the chrome/blk stands (nice combo you have)
