Daedalus Dynamic Audio-One Speakers
0 Members and 1 Guest are viewing this topic. Read 18927 times.
JCC
« on: 30 Jun 2004, 02:35 am »
In February, after some strong recommendations from audiophile friends, I decided to try out a new set of speakers from Daedalus Audio. Sure, I arranged to be able to return them, and got a good price for being among the first to try these speakers.  Anyway, after several months of listening, I find that I can’t part with these speakers, and I have prepared the following review.
Daedalus Audio owned by Lou Hinkley, has been well known in the pro-audio world for some years. The new Daedalus Dynamic Audio-One (DA-1) is Daedalus’s largest speaker, and it’s first movement into the Audiophile community. Because of Daedalus heritage as a pro-audio company and Lou Hinkley's background as a musician the Daedalus
DA-1 embodies a somewhat different philosophy as compared to many audiophile speakers:
● Live Music is the point of comparison – High end pro-audio is often used in recording studios and at live events.  The reference is realistic reproduction, instead of comparison to other systems.
● Dynamic Capability – The dynamic variance of live music can be extreme and the involved speakers must be able to replicate the performance. Few audiophile speakers can handle the required extreme dynamic range.
The observable and impressive components, including the cutting-edge driver construction, the sophisticated real-wood cabinetry, the scrupulously accurate crossover networks as well as the ability to handle extreme dynamics are discussed in detail on the Daedalus website (www.daedalusaudio.com). No effort or expense seems to have been spared in the design and construction of the Daedalus DA-1.  When you first open the boxes, you notice the fantastic cabinetry with old world dovetail construction (seldom seen today).  The pictures on the Daedalus website, don’t do these speakers justice, with finishes available in oak, walnut or cherry. The beautiful cabinetry of the DA-1’s blends well with most period and modern furniture. The general quality of fit and finish is outstanding. Without spikes, the Daedalus is solidly stable as some other spiked speakers.
I asked Lou about the hard wood and he indicated that in pro-audio, MDF will not work because with the rough handling breakage is a problem. Furthermore, he indicated that a properly designed hard wood cabinet of roughly 100 lbs would be as stiff or stiffer than a 300 lb MDF cabinet. When you start to listen to these speakers you become a believer. These speakers are rock solid, without a trace of resonance. The DA-1 is a four-way system with a complicated phase coherent crossover. Daedalus is not releasing the crossover frequencies. On the DA-1’s front panel is a pair of 8" woofers, and the bottom of the two crosses over at a lower frequency than the other. Above the woofers is a 5” dynamic midrange with it's own built-in enclosure. Each DA-1 has two tweeters, offset by 10% to provide a large sweet spot. There is a rear facing aperiodic port, which you can easily use to reinforce the bass with corner placement.
Listening:
When I first fired up the DA-1’s, I quickly discovered that true to their pro-audio heritage, that they are the most dynamic speakers that I have every experienced. With 96 DB efficiency and the ability to take nearly all the power that you can throw (600 watts per side) at them, you can turn your home into a concert hall. When listening to the 1812 Overture, I wanted to duck under the cannon balls.  Furthermore the DA-1 sounds like a single large driver, and I can’t find the crossover seams. These speakers have great coherence and solidity from lower bass through the upper treble. Through additional months of listening, this first impression did not fade, and these speakers are very forgiving about room placement. About the only adjustment is a three way treble switch, and placement distance from the corner. When about 3 feet from the corner, I found them to be essentially flat to about 30 Hz. Moved into the corner, the reinforcement brought the bass down to 25 Hz, and down 3 Db at 20 Hz.
Over the past four months, I have continued to listen, and the speakers are now fully broken in. So how do they sound?
Lets start with the DA-1’s treble performance, which is so revealing and musical. I can follow the bloom and decay of cymbals, and hear the background noise of the recording process.  I can hear air in recordings that I have seldom experienced in 40 years as an audiophile. The previous time that I heard this air was in auditioning Quad ESL-63’s and again when listening to an Apogee Mini Grand. The back half of the notes with the lengthy bloom and decay came through providing realistic in the concert hall sounds.  Furthermore, these speakers are as outstanding with intimate small-scale ensemble music as they are with a symphony orchestra.
The DA-1’s high frequency balance, although quite relaxed, is not at all lacking in treble energy.  A familiar recording, Toolbox (VTL 008) nearly stunned me with how meticulously delicate the plucked strings and percussion instruments were, and how precisely they were placed in the soundstage, which was very deep and wide. It is common to hear specific instruments 8 feet external to a speaker’s placement.  Sometimes with all of this detail other speakers can sound bright and lose musicality.  Not so with the DA-1’s which if the recording is good, sound musical and warm and real.
But the DA-1’s exceptional performance, which extends through all frequencies, somehow seems to bring air and character throughout the midrange and the bass. When you listen to a cello solo on most speakers, the output is commonly recessed. Not so with DA-1 where the cello sounds to be right there, with dynamics and precision that are so realistic. And the midrange with voice and plucked string, and the ensuing harmonics and decay come through in such a lifelike fashion. Air and decay is traditionally thought to be a treble quality, but the fact is that it comes through in other frequency spectrums. I listened to the Indiansong, which is the fourth cut of Toolbox. In the nylon string guitar solo I could discern the movement of the hands on the instrument. This due to the subtleties of sound when one moves there hands on the strings In other cuts with a close miked piano, you can close your eyes and hear the movement of the pianist hands in the sound stage. I don’t think that you will hear that on any but the world’s best speakers, and that includes the DA-1.
One of my favorites is “Tous Les Matis du Monde,” Valois V4640, which features Jordi Savall’s baroque and classic orchestra. This is a massed strings and choral orchestra. In this recording the massed strings, and the choral voices came through with breathtaking detail. The solos and then the choral voices came through with exciting purity, with the strings moving across the soundstage bringing chills to my spine, and I wondered how close the DA-1’s compared to the real concert because this playback came across with such startling realism.
The fact is that the performance from these speakers throughout the audio spectrum is about as good as it gets, but there are a few areas where the DA-1’s surpass nearly all of the very best speakers.
● As stated previously, these speakers are the most dynamic I have ever heard (96 DB efficiency, 600 watts per side). So when there is a large dynamic range on the recording the DA-1’s really excelled. With the DA-1’s, the combination of depth, detail and dynamics are beyond what I had heard before. Certainly the Quad’s or Apogee’s mentioned above are no match for the dynamic capability of the DA-1’s. Surprisingly, however, the DA-1’s still excel in the ability to handle the soft low-level passages for which the Quad’s and Apogee’s are so famous.
● Most speakers have narrow sweet spots, and the offset tweeters of the DA-1’s provide for an enlarged sweet spot. With this configuration you can listen with multiple companions and still hear the complete performance. In addition this provides a quality that grabs you when you walk through the room.
When Telarc’s CD-80296 “Pictures of an Exhibition first came out, it was portrayed in the audiophile press as the first CD to surpass the capability of vinyl. The caveat was that you had to be able to handle the dynamics in your system to properly experience this fine recording. I bought and I listened, and I wondered why others considered this recording to be excellent. With the new Daedalus DA-1’s I eventually got around to playing Pictures. Wow, the reviewers were right, this is a tremendous recording. With it’s wide swings in dynamics you really need a reasonable amount of volume to hear the softer passages, and when passages move to ones with greater amplitude and the bass drums are played, the dynamic contrast is spectacular. Well, I knew in advance that the DA-1’s would handle the dynamics, and they did superbly. What further impressed me was the DA-1’s ability to handle the quiet passages reproducing all of the lower level detail, bloom and decay and to so superbly handle the orchestral sound stage.
I always liked Chesky’s “New York Reunion” (JD51) with McCoy Tyner, Joe Henderson, Ron Carter, and Al Foster. When I pulled it from my cache of CD’s, I began to hear low-level details that I had not previously heard. The treble bloom and decay shined and the soundstage was alive.  You could almost see McCoy Tyner's fingers move across the piano, and Al Foster's drums and cymbals were on the sound stage. You could place the drums and cymbals in their own space, a few feet apart.
Anyway, the better the recording, the better the DA-1’s sound. With the DA-1’s ability to handle all of the low level details, it will include the good with bad. When I played “Cowboy Junkies The Trinity Sessions”  (RCA 8568-2-R), in which the first cut features the a cappella voice of Margo Timmins, the clarity and naturalness of her voice was so real that I could close my eyes and feel her presence. This recording was made at the Church of the Holy Trinity in Toronto, and this venue is famous for it’s ambience. The ambience was reproduced with realism, and the overall musical details were still clearly reproduced, and the result seemed to create a haunting surrealistic portrait of the session.
When I listened to the Verve SACD recording B0001 128-06 “What a diff’rence a day makes!” by Dinah Washington, I could distinctly hear the superiority of the SACD format. This is one outstanding recording from the 60’s, and it seemed to bring Dinah back. Likewise, when I listened to Pink Floyd Dark Side of the Moon comparing the new SACD version to the older Mobile Fidelity version, the superiority of the new format was easily recognizable with the DA-1’s.
Comparisons:
I could go on and on through recording after recording, describing my overall impressions which are generally outstanding. But in completing this review, I felt a need to hook up my older speakers. These are a demo set of two-way Diaural speakers from Diaural, which are very fine speakers in their own right. Before I started, I know that they would not handle the dynamics because I have previously blown woofers at high volumes.  I also knew that that would not produce the deep bass that the DA-1’s handle so well. What I didn’t expect was the DA-1’s superiority in ability to provide low-level details. It was fact that the DA-1’s with their 4 way crossover, produced detail and musicality that was superior. This was particularly evident on complex orchestral passages (Telarc CD-80296 – Pictures of an Exhibition) where an occasional cloud was lifted when I switched back to the DA-1’s.  Another major difference was in the bass foundation of the DA-1’s, which was superior. There was a certain plumpness to the sound with the DA-1’s, which disappeared when I switched back to the Diaural’s.
Are they Perfect?
Although, I had difficulty finding deficiencies in the sound produced by these speakers, I have found that you really can here a difference in amplifiers. When I started, I was using an 8th Nerve modified Carver ZR1600. In a lot of listening I felt I was not hearing all that these speakers could produce. I sent out one of my ZR1600's to Reference Audio Mods, for their enhancement, and wow what a difference. These speakers are so good that they will highlight the weak-point in your system, and it likely won’t be the DA-1’s. Like me you might catch upgrade fever.
And with all of the ability to produce low level details you can really hear your recordings, and you might be disappointed with some of your old favorites. When I buy a recording, one of my parameters is sound quality, and I have had very few disappointments. On the other hand, my wife does not have this consideration, and she has been disappointed with some of her recordings. The DA-1’s are mercilessly revealing, and you will hear it all, both the good and the bad.
Conclusion:
I don’t know that the DA-1’s are the best speakers available, but they certainly are among the best, and the best that I have ever auditioned, and by far the best that I have ever had in my home. Furthermore they are certainly in the top few in their ability handle extreme dynamic range with audiophile precision. These are one outstanding set of speakers, which I highly recommend.
Associated Equipment:
1.   Pre-Amp – Sony TA-P9000ES modified by Stan Warren
2.   Amplifier - Carver Professional ZR1600 with Reference Audio Mods modification
3.   Philips SACD 1000 modified by Stan Warren
4.   Speaker Cables - Alpha Core Goertz PYTHON MI2
5.   Stealth Interconnects – SCR
Specifications DA-1
U.S List Price ---------------------- $6400 / pair
Drivers High Frequency (X2) --- 1” Silk Dome offset 10 Deg.
Drivers Mid-Range (X1) ---------- 5” Dynamic  (in Hardwood Sub-Enclosure)
Drivers Low Frequency (X2) ---- 8” Dynamic Loudspeaker
Frequency Response ------------ 30 – 20 kHz +/-  2 db (Room Response)
--------------------------------------- 45 – 20 kHz +/-  1 ½ db (Anechoic Chamber)
Sensitivity ------------------------- 96 db  1w/1m
Continuous Power Rating ------ 350 watts
Nominal Impedance ------------- 6 ohms
Tweeter Attenuation Switch --- 3 position
Crossover ------------------------- Phase and time aligned passive internal
--------------------------------------- crossover - Full acoustical damping with
--------------------------------------- matched high power resistors,
--------------------------------------- poly capacitors, oxygen free copper
--------------------------------------- inductors, Gold connectors
Internal Wiring ------------------- Silver-Sonic cable by DH Labs
Enclosure Type ------------------- Tuned Port Aperiodic Vent (Rear)
Enclosure Material --------------- Solid Hardwood with Dovetail joints
--------------------------------------- 1 ¼” Baltic Birch and Walnut baffle
--------------------------------------- Hardwood bracing
Cabinet Finish -------------------- Hand-rubbed Oil Varnish Finish
Dimensions (H”x W”x D”) ------- 45” x 11” x 16”
Weight ----------------------------- Approx. 102 lbs each
Warranty -------------------------- 5 years
mgalusha
« Reply #1 on: 30 Jun 2004, 03:53 am »
A very nice write up and a most interesting speaker. Now if you just lived in Colorado I'd try and wrangle an invitation for a listen. :)
mike g.
  • Speakers....What Speakers ?
« Reply #2 on: 30 Jun 2004, 05:55 am »
Look pretty good and your quote's there.... http://www.daedalusaudio.com/
-Richard-
« Reply #3 on: 1 Jul 2004, 04:22 pm »
Hi Jesse,
A beautifully written review that shows a great deal of care and careful consideration...and nicely balanced as well (like your Daedalus speakers).
The price for these speakers seem extremely competitive... especially for the level of performance you indicate they are capable of...perhaps the Daedalus are the new for-the-price champions that will make other speaker manufacturers sit up and take notice...
I also wish I lived closer to you in order to hear for myself what these speakers can do...
I am especially interested in your description of the "air" that these speakers reproduce...that is something that really interests me lately...your comparison with electrostatic speakers like the classic Quads has really peaked my interest.
Thanks for the insights...and opening the door on what could very well be a new classic speaker on the "cheap" (relatively speaking of course).
Warm regards
-Richard-
Mastersmith
I'm lucky enough to own a pair!!!
« Reply #4 on: 2 Jul 2004, 05:54 pm »
I recently decided to revamp my system:  Bryston 7BST mono blocks, NHT 3.3 speakers, Rogue Magnum 99 pre amp, Meridian 508-24 cd. Nice system but no longer engaging for me. After some research I decided to move to the world of SET. Now I needed some speakers which were much more efficent than what I had ( NHT 3.3 87db).  After some research I decided to buy some Cain & Cain Abby's (Normal version). I had just recieved them when I met Lou Hinkley and invited him over to hear the speakers and he agreed to bring a pair of his  Daedalus speakers as well. Now the Abby's are very cool looking speakers, every one that came into the house remarked on the styling and how cool they were, but I still hadn't heard them yet. At this point I still have the Magnum pre amp but the SET amps were not built just yet so we set up to one of Lou's pro Hafler 9505 SS amps. Lou and I set up the speakers, Abby's first and picked some refference CD's, we played a couple of cuts to get the feel.  Then we set up the Daedalus speakers and played the same cuts, get the @#&%$ back, what just happened.  I always enjoyed the NHT 3.3 and I"ve had some Martin Logan Asents that I liked as well but Lou's speakers brought a whole new experience to the music. I grabbed more music and continued to play my favorite cuts having a new experience with each disc.  He agreed to let me borrow them for a week so I could continue to compare the two and within one day I had decided these speakers were not leaving the house. I was in no way prepared to purchase this second set of speakers yet I was seduced to the point of scrambling to own them. Luckly for me this was a pair of demo's from the beta testing phase and Lou kindly gave me quite a deal,  but I have to say even if that was not the case I would have found a way to purchase these speakers. These speakers are fine funiture grade hardwood with dove tailed joints and a killer hand rubbed finish.  They are small enough so that I can move them easily by myself unlike the NHT 3.3's. The sound is warm, full, and engaging. No listener fatigue whatsoever.  These speakers pull me in from other rooms of the house with aspects of the music I have never heard before. I don't have all the articulate nomenclature that the reviewers have,  but I know  I have stopped listening to the gear and and I've been taken away by the music to the extent of having the music bring tears to my eyes.  This is what I've been looking for for eight years.  I haven't heard every speaker out  there but from what I have heard these are by far the best. This is one component I may have for the rest of my life.
I'm looking forward to adding the SET 300B amps to the system and I'll post again once I've had a chance to listen.
-Richard-
« Reply #5 on: 3 Jul 2004, 01:27 am »
Hi Mastersmith,
Thanks for sheding more light on the Daedalus speakers through your first hand experience with them...
I reread your very enthusiastic "review" but could find no reference to which pair of Daedalus's you own... although I assume it was the same as the pair that Jesse reviewed...the Daedalus Dynamic Audio-One.
Thanks for your feedback...any further thoughts would be most appreciated...perhaps after you get your SET amp set up...I am most interested to hear how that affects the performance of the speakers and your experience of them...perhaps you could compare the SS and tube SET amps through the Daedalus speakers... just thinking out loud...
Warm regards
-Richard-
Mastersmith
« Reply #6 on: 3 Jul 2004, 03:19 pm »
Yes they are the DA1.  I have heard the speakers with a set of Bottlehead  300B monoblocks at Doc. B's place and the speakers sounded great. At 96db 1 watt 6ohm there was no problem driving them with headroom to boot. These amps are only 8 watts a side, but super clean 8 watts. Doc has some great gear and for the money it can't be beat.  He sells a little pre amp for $300 that is just amazing, it replaced the Rouge Magnum 99 in my system. I'll post again once I finish building my 300B's.
JCC
Daedalus DA-1
« Reply #7 on: 6 Jul 2004, 02:30 am »
Hello Mastersmith,
I am very interested in your results with a Set Amp. Interesting how you have taken an opposite approach. While I drive with 350 watts per channel you use 8. But these speakers are so efficient that 8 will probably do except for very large dynamic swings. Anyway, posts of your future results will be most appreciated.
JCC
Daedalus Audio
thanks for the kind words!
« Reply #8 on: 8 Jul 2004, 05:22 pm »
If anyone is interested in purchasing/ auditioning these speakers after reading JCC's review we will be offering an introductory discount. More info will be posted soon or contact us @ www.DaedalusAudio.com or 360-366-9944
thanks,
 Lou
audiojerry
« Reply #9 on: 9 Jul 2004, 03:40 am »
Jesse, thank you for your very thorough and thoughtful reviews.
JCC
Daedalus DA-1 at Rocky Mountain Audio Fest
« Reply #10 on: 3 Oct 2004, 05:37 pm »
The Daedalus DA-1 with the RAM modified Carver will be at  the Rocky Mountain Audio Fest.
Stop by and see this outstanding combination.  :mrgreen:
EarRelevant
« Reply #11 on: 5 Oct 2004, 02:00 pm »
In the past year I bought a pair of Daedalus SR-823, the DA1's little brother.   I got them for multi-purpose use as occasional acoustic guitar PA speakers, but mainly for music and home theater.   I am pleased.
The SR-823 are 97db efficient and handle up to 250 watts.  They are sold in L-R mirror pairs, image very nicely and go to about 40hz.   I replaced 23-year-old ADS L810 speakers with them.  An M&K sub delivers the bottom octave.
Due to cabinet design and driver orientation, I would expect the DA1 to image even better and have deeper bass.  Their 600w power rating at 96db efficiency means they can play perhaps 3-4 db louder than the SR-823.
It would be fun to compare the SR-823 to the DA1!
By the way, I am using Lou's W-803 monitor (on the floor, but standing on end with tweeter up top) as the center channel in a home theater setup.  I understand he is working on a matching center channel for the DA1.
I have fantasized about a full-blown 5.1 surround system with the DA1 for the mains, the upcoming center channel, and the SR-823 for the surrounds.
As for the RMS mods to the Carver amps, does this refer to the Carver Pro digital amps?
I look forward to comments about the combination of the DA1 and Carver Pro amps from those going to the festival.
Ken
JCC
Daedalus & Carver.
« Reply #12 on: 5 Oct 2004, 02:43 pm »
Hello Ken,
Thanks for the note. Yes, I am referring to a modified Carver Professional ZR1600, but there is very little Carver left. It has a Carver Case and lots of modification.
This amp far exceeds the stock configuration, and I think it goes great with the Daedalus, but we will have to wait for Lou's comments from the show.
« Reply #13 on: 5 Oct 2004, 04:19 pm »
Quote from: EarRelevant
EarRelevant,
    How would you say the SR-823's would sound being powered by an 8 watt tube amp ? Since the are very efficient....might they be a good match ? Thanks !! :) [/list:u]
      Just noticed...your first post....welcome !! :) [/list:u]
Bill Baker
    • Musica Bella Audio
« Reply #14 on: 8 Oct 2004, 12:01 am »
Actually, you will be able to audition these speakers with various amplification in Lou's room at the show.
 So far, there will be a custom built Signature Jolida 502, one of Doc's amps, the Butler 100A 300B mono blocs (100 watts per) driven by a custom built Ming-Da preamp. I was unaware of the Carver but it should be an interesting display of different technologies driving these speakers.
 I am very interested in hearing reports back from the show.
  Hopfully, an audition pair will be in my showrrom by year's end.
EarRelevant
« Reply #15 on: 10 Oct 2004, 06:09 pm »
EarRelevant,
      Hello.  One of my favorite old power amps has a wattage meter on front.
      With the SR-823, it seldom goes above 5-6 watts, even with fairly loud listening.   Usually, it is under a watt!
      I think you will be pleased with the volume using an 8-watt tube amp.
      Ken
« Reply #16 on: 12 Oct 2004, 06:48 am »
EarRelevant,
      Ken
Thanks Ken !!! :)
JCC
Daedalus DA-1 - Surround
« Reply #17 on: 21 Dec 2004, 10:50 pm »
As I listen to these speakers, the more impressed I become. Listening to the SACD "Live at Red Rose Music" and many other recordings from rock to soft instrumentals, I can only comment that these speakers with an appropriate system are among the very best.
Recently, I was speaking to Lou Hinkley at Daedalus, and he told me that he was developing center and rear speakers for surround. Knowing Lou and the quality of his work, a Daedalus surround system should be outstanding.
tyee
« Reply #18 on: 22 Dec 2004, 08:49 pm »
I get mine next week. It's been a long wait but I know it's worth it!!
tyee
Bill Baker
« Reply #19 on: 22 Dec 2004, 09:56 pm »
I should have mine in the NY showroom soon enough. They are already singing along in our Midwest location, Jam'n Audio, so I have been patiently waiting.
 I agree, a Daedalus HT setup should be killer!! I may have to venture into this in the future. (home theater that is).
