Metric Halo ULN-8 For Sale $3500.00
0 Members and 1 Guest are viewing this topic. Read 3675 times.
adampleiman
« on: 14 Feb 2013, 10:24 pm »
SAVE $1200.00! Unit only used in smoke free professional studio setting.
I absolutely love this interface. I am only selling because I do not need 4 of them. I have 2 to sell, this listing price is for 1 Metric Halo ULN-8, they are in perfect working order and sound amazing. For the price you cannot beat this box. 8 boutique Pre Amps, with built in selectable character, eq, dynamics, amp emulation, di inputs... Basically anything you need to get the best quality audio into your digital audio workstation. Not to mention that the converters alone are worth the price of the interface without the pre's. Below are the details from Metric Halo.
8 Channels of Archival Grade 192k A/D converters
Exceptionally flat, low-distortion A/D conversion
DC-coupled for ultra-low phase distortion
8 Channels of Archival Grade 192k D/A converters
Exceptionally flat, low-distortion D/A conversion
2 Channels of Archival Grade 192k D/A converters with integrated headphone amp
Same high-quality DC-coupled conversion
Dedicated, digitally controlled high-power headphone amplifier
8 Channels of Exceptional Remote Controllable Ultra-Low-Noise Clickless Preamps
Custom designed Digitally Controlled analog preamps
Metric Halo Zero-Cross switching technology for clickless operation
Discreet gain and trim stages for ultra-high headroom operation (supports +20 dBu input)
Analog Send/Return architecture for analog access to preamps (pre A/D)
Analog domain sends from preamps (mult'ed pre-A/D)
Analog only preamp operation capable (with fine trim)
Integrated switcher to allow insert of external analog processing pre-A/D
2 Channels of Exceptional DI inputs suitable for instrument or turntable inputs
Ultra-High-Z for no instrument loading
Balanced or unbalanced operation
Jumper configurable pre-trim gain
Integrated Surround Monitor Controller
Provides switching between any set of user specified sources (FW, AES, Analog, Mix)
Analog domain gain control for monitor output from Front Panel or computer
Supports input and monitor paths from Mono to 7.1
8 Channels of 192k capable AES Inputs and Outputs
Available as computer I/O or direct routed I/O for converters
Support full channel count at all sample rates
Professional interfacing
Comprehensive Front Panel Controls
Full support for standalone converter and preamp operation
Sample Rate selection
Clock source selection
Input source selection
Phantom power control
Tactile Control of Input and Output gains
Gain level indication with MH Digital Dual Vernier Technology
Numeric gain level indication while changing gains
Tactile Control Cans level
Tactile Control Monitor Controller gain (mono - 7.1)
Preset recall
Multichannel gain linking control
Monitor Controller control surface
User-controllable brightness
User-controllable knob sensitivity
Comprehensive, High Resolution 15 Segment Precision Front Panel Metering
Real, functional metering for analog inputs and outputs
Unique 'Meter on knob' functionality
Multi-color signal level/presence metering for AES inputs and outputs
Comprehensive Clocking (Internal, Word Clock, AES)
Dedicated internal clock sources for all rates
Dedicated MIDI I/O for Control Surface interfacing
MIDI Input and Output on standard DIN connectors
MIDI transported to computer via FireWire for use in connecting Mackie Control protocol Control Surfaces
Dedicated SMPTE LTC I/O for Timecode without sacrificing any audio channels
Properly conditioned and band-limited SMPTE I/O on TRS balanced connections
Available to any CoreAudio application as audio streams
Directly routable to Record Panel SMPTE decoder
Rock-solid, time-tested fifth-generation software and drivers
Integrated Mixing and Deep Instantiable DSP Processing (Includes Full +DSP License)
Fully configurable multibus mixer with surround support (up to 7.1)
Full Send/Return architecture
Ultra-low latency, on-the-metal monitoring
Insert model for inserting zero-latency plugins
Insertable +DSP plugin graphs for configurable processing
Insertable graph macros for complex, pre-configured processing
Includes over 100 high-quality processing plugins, including:
MIOStrip -- channel strip processing
Dynamics (Compressor and Limiter)
Transient Controller
EQ (6 band and 12 band)
Signal Processing primitives
Crossovers
and much more. . .
Per-channel and Per-bus Insertable Character™
FireWire Interfacing with ultra-stable, ultra low-latency drivers (FW400 & FW800 supported)
Supports Mac OS X v. 10.4 and newer (PPC and Intel)
Supports 32-bit and 64-bit kernels
Bidirectional Control Surface Support
Integrated Front Panel Tactile Controls
Eucon Control Surfaces
Mackie Control Protocol Control Surfaces
Integrated Multichannel Recorder (Record Panel)
Multichannel, multi-box tape-style high-performance recorder
Exceptional Stability and Sound Quality
Realtime waveform display
Extensive File Format support (BWF, WAVE, CAF, AIFF, SD2)
BWF timestamping from TOD or LTC (any input channel or dedicated SMPTE input)
Support for basic BWF metadata
Support for limiting record file size and seamless file breaking
Seamless manual file breaking (with timestamping)
Support for mirrored recording (recording to two drives at once)
Multichannel take playback
DC-Powerable
High quality, custom designed formed powder-coated aluminum case
Strong
Light weight
Scratch and fingerprint resistant
Smooth contours for snag-free transportation in a gig-bag
Rack-mountable with included rack-ear kit
Exceptional Power Performance (only 32 Watts)
Low mass (6 lbs / 2.7 kg)
Extremely Compact (everything in 1 RU)
Future Proof, Expandable, and software-enhanceable
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Re: Metric Halo ULN-8 For Sale $3500.00
« Reply #1 on: 15 Feb 2013, 06:12 pm »
Hi Adam,
     Welcome to Audiocircle.
Kind regards,
Guy
dkmooers
« Reply #2 on: 14 Apr 2013, 04:17 am »
Hey Adam, do you still have a ULN-8 available? Also wondering if your ULN-8s all have the glossy front panel, as I've seen some with a matte front panel like the LIO-8.
Devin
