0 Members and 1 Guest are viewing this topic. Read 3770 times.
Hi folks, I am selling a Moerch arm with its highest mass (14g "blue dot") armwand to fund an upgrade to the Moerch DP-8. I have another couple armwands of less mass, and I am wondering about the need to get another high mass armwand vs keeping costs down and just adding weight at the cart end by using something like the heavy EZ Mount Soundsmith screws to one of my lighter Moerch armwands. With the Soundsmith heavy screws, I can get to right about 14g, the effective mass of the armwand I will be losing. Are there any sonic advantages of doing one or the other (putting cost aside for now)? With a cart that benefits from a higher effective mass tonearm of course (ZYX in my case).
I talked to Pete Riggle about making a VTAF for the Sonus Formula 4. I never used his device and didn't know how it worked, but he was anxious to make one for the arm. It even entailed extending the platform that holds the cueing device, for lateral stability - guides. That inspired me to look into it further and it seems unsuited for lightweight arms. My efforts to find more info on the VTAF were thwarted by a friend of his who posts on these forums and I didn't pursue it further. Before the posts were changed, by request of the OP on Karma, I read about Rega arms falling out of their mount and similar stability problems. I'm not sure if this was misuse of the product or or what. It was enough to scare me off. I'd be interested in further info and suggest you proceed with caution. neo
If an arm fell out of the VTAF I'd suspect that either the arm wasn't seated properly or that it was raised so high as to be at the end of the post. Keep in mind than the VTAF doesn't lock the arm tight, it's snug, but it is possible to lift the arm out of the VTAF. So, yeah, I'd agree with the misuse.
That's interesting, do you have one of these? I get the impression that the arm sits on a number of inverted cones? In theory that should decouple the arm from the mount. Most arm designs mass couple the arm to its base with 1 or 2 bolts. If that is the case, I think it might work better on higher mass arms and housings. neo
