H frame enclosure question for a dumb dumb
0 Members and 1 Guest are viewing this topic. Read 2123 times.
xero
« on: 12 Feb 2013, 02:47 am »
hello all,
i have be interested in open baffle speakers for some time and i a m considering building some H-frame open baffle bass units.
so here is my question.  when you look at  voice of the theater bass units they sometimes have a horn type flare. why have we
not seen the same type of flare built into an H-frame?
thanks in advance
E
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: H frame enclosure question for a dumb dumb
« Reply #1 on: 12 Feb 2013, 02:59 am »
Well, I am not sure what exactly that speaker is, but sounds like a horn loaded speaker, so the horn flare would be the mouth of the horn.  The H frame is completely different in that it doesn't use compression as its open baffle. Baffle width would factor into off axis cancellation frequency.
xero
« Reply #2 on: 13 Feb 2013, 06:45 am »
wolf von langa has produce something similar to what i am thinking.
here is a link to his design.  this is an open baffle dipole bass with wave guide.  all drivers are field coils!
http://www.hqspeaker.com/cabinets/a820i-design-model-2.html
JohnR
« Reply #3 on: 13 Feb 2013, 07:25 am »
This is another one that seems similar (posted in Open Baffle circle):
http://www.audiocircle.com/index.php?topic=112246.0
xero
« Reply #4 on: 14 Feb 2013, 02:38 am »
yes, i have seen these before but forgot about them when i posted my example.
the other question that i have is that in these designs the woofer is partially covered
by the wave  guide.  why is that.  why not make a curve in the waveguide so that
all of the driver is exposed.  just curious.....
thanks again
