0 Members and 1 Guest are viewing this topic. Read 12681 times.
There was also a plastic tripod that clamped on the spindle. I forget what that was called. neo
On fleabey, weights are advertised as clamps most of the time. It can be confusing for the uninitiated.There are 2 basic types of clamps, ones that hold down the record and keep it from slipping on an acrylic or metal platter, and reflex clamps. The Michell clamp can be used either way. It comes with a felt washer that you can put under the record and use reflex action to partially flatten a warped record or create a kind of pressure coupling of the record. I have one of these, but I never use the washer. I also have a Sota reflex clamp that is designed for the Sota platter, though it can be used on most tables. I have the Sota disassembled, I plan to use the platter/bearing for a custom table. The clamp comes in handy for my DIY record cleaning machine, where I mostly use it. The Clearaudio Cleaver clamp just holds down the record. I'm pretty sure it was originally the Souther Cleaver Clamp and was designed to work with the Souther linear arm which rests on top of the spindle. Clearaudio bought Souther and and now makes both. I guess John TCG was right about inflation from the '80s till now. The plastic disc was originally $10, and now $30. Sorry to digress, but it seems to me it was originally worth about $5, and now maybe $15, but after all it's an audiofool product.Most conventional mats don't require the use of a clamp, and of course opinions about that vary. Back in the day there was a little rubber clamp that looked like a chess pawn only a little bigger. It was called the Pig - maybe $5. There was also a plastic tripod that clamped on the spindle. I forget what that was called. Most high end tables that come with acrylic, delrin, methacrylate or metal platters require a clamp or weight.neo
Hi,I'm new to this forum. I discovered it while searching informations about clamps.This is a question I often ask to myself: are those clamps used to prevent the slipping of the LP on the platter to damage the platter or does it have only sonic qualities?If anyone knows...Thanks
Is there a clamp weight versus motor torque ratio we should abide by?
