Bookshelf Speakers around $1000 that sound good close to a wall without stands
0 Members and 1 Guest are viewing this topic. Read 10275 times.
steveoat
I am looking for bookshelf speakers to mount on a dresser in my bedroom.   They will be close to the wall and without stands.
Any recommendations?
ltr317
Ported speakers with the port in the back will not be good candidates for your situation.  I suggest looking at models with the port in the front or sealed (acoustic suspension) speakers.  Do a search for them and see if there reviews associated with the models.
PSB Guy
If you want to stretch your budget a bit, I would check out Salk WOW1 monitors. They're front ported so they can go against the wall and they go down to 42Hz.
Cornelis
Napalm
I'll save you $600 and will recommend these classics:
http://www.energy-speakers.com/bookshelf-speakers/?sku=RC-10
with a review (including measurements) here:
http://www.soundstage.com/revequip/energy_rc10.htm
They come in a variety of colors to match your furniture.
The finish is impeccable.
They're rear ported but come with port plugs would you need them.
From personal experience you won't need the plugs unless you stick them in room corners. Close flat walls are fine.
With grilles on the treble is present but non-aggressive - just right for a bedroom.
wisnon
www.vanatoo.com
They are active with a built in Dac and won a the Maximum Mojo award. Sold direct , so only $499 a pair.
Charles Calkins
Polk RTiA3. $399.95 a pair
                                                             Cheers
                                                             Charlie
Phil A
Www.directacoustics.com
bummrush
Little Pioneers
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
I see this question, or ones similar to it often - suggest speakers that sound good close to walls.  And there's a lot of confusion in the answer often.
The short/simple answer is all speakers will be compromised in a near-wall situation.  Every speaker will suffer a performance hit when close to walls because of relatively high amplitude reflections causing summation/cancelation resulting in a less-flat overall response.  If near wall placement is a requirement, it's something you have to live with.
A couple things that may improve the situation:
- How is the speaker tuned?  Many bookshelves tune a bit higher than optimal to give a hump in the bass response, and the impression of having more bass than there really is.  In a near wall placement, that's the LAST thing you want because the bondaries will further boost the bass resulting in an overly fat and tubby sound.  What is optimal is an Extended Bass Shelf alignment.  Instead of explaining what that is, google if interested.  But result of an EBS alignment + near wall is much closer to a flat end result.
- The closer a speaker is to boundaries, the more important it is for the cabinet to be completely dead.  The walls will reflect the sound of those resonances just like they reflect everything else, the closer the wall is, the higher in amplitude those reflections will be when they reach the listener.
- Port placement is NOT a huge issue.  With smaller bookshelves using 5-6" woofer, they just don't move all that much air.  In that case all you need is 4-6" of space from the port opening and the closest wall.  With larger 7" woofers you need a bit more space, but still only 6-8" is plenty.
- Put some 4" thick absorption panels directly behind the speakers that extend at least 1' past the speaker boundaries, thicker and bigger if possible.  If you can control the rear wall reflections, it can help mitigate the negative impacts.
Hopefully that helps.  Unfortunately nobody tells you what kind of bass tuning they're using, such as the EBS I mentioned above.  Knowing that would help customers make an informed decision.
Rclark
www.vanatoo.com
An XBL^2 motor and has passive radiator on the back. built in amp, dac, etc. Blam, that's quite a deal there for $499.
PRELUDE
Take a look at this.All you need is a pre amp.
http://app.audiogon.com/listings/monitors-paradigm-reference-active-20-powered-speakers-2013-02-09-speakers-07504-paterson-nj
reddmadder
Blumenstein audio.com
geowak
NHT M-00 powered monitor speakers . You can also get a matching sub. But you might not need it. I don't know if they are still available in the US?
