Turn my $2000 USD into a tube amp!
0 Members and 1 Guest are viewing this topic. Read 10163 times.
Shogun
Re: Turn my $2000 USD into a tube amp!
« Reply #20 on: 15 Feb 2013, 05:14 am »
http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=55
Musical Paradise MP-501, a PSE integrated amp that deliver 55w from four KT120.
mpcrelly
« Reply #21 on: 15 Feb 2013, 06:45 am »
Thanks for all the suggestions.  I finally decided on the Rogue audio cronus magnum version.  just hooked it up tonight, but roomate is sleeping, so higher volume tests tomorrow.
should I expect a period of time where the new tubes will improve in sound or am I up to speed after they warm up and the bias is set properly??  (like 30min?)
thanks!
Ericus Rex
« Reply #22 on: 15 Feb 2013, 01:06 pm »
thanks!
If the tubes are brand new you should expect the most burn-in change within the first 20 hours, then a more subtle change within the first 100 hours than very little change after that.  I'd recommend monitoring the bias every 5-10 hours for the first 20-30 hours, then every 3-6 months after that.  The great thing about the Cronus is how easy checking bias is with the built-in meter.
Congrats!
roscoeiii
« Reply #23 on: 15 Feb 2013, 03:35 pm »
thanks!
And I would make sure the tubes are warmed up before setting bias. Say 30 min or so.
