Please help me w/ Itunes Playback Problems, Repeats, skipped Songs
0 Members and 1 Guest are viewing this topic. Read 1462 times.
morganc
Hi Guys,
     I've read of others with similar problems that were easily fixed, but I can't find the fix now.  I'm having the following problems. I'm running ITunes into AudiNirvana in a 2011 Mac Mini.
1.  When playing an album or playlist, after finishing a song it will often(but not always) replay the same song for 5-15 seconds then skip to the next song.
2. If i start playing album A, then switch to Album B or Playlist B, it will correctly play a song, or two of B, then switch back to A or some other random song.
3. When using the Apple Remote, there is often a 5-15 second delay from selecting a song to getting playback of the song.
Any and all help would be appreciated.  It's driving me mad  :evil:.
« Last Edit: 10 Feb 2013, 04:53 am by morganc »
morganc
Re: Playback Problems, Repeats, skipped Songs on Mac Mini
« Reply #1 on: 10 Feb 2013, 03:49 am »
Btw the remote app is via an IPad........
abernardi
  I've noticed similar problems come up with Audirvana.  If I start playing an album from my iMac and then from my listening position, I use the iPad w/ the remote app, that's where I run into problems.  If I choose a cut from a different album on the iPad, it doesn't recognize the album change.  For example,  if I try to play cut #2 on a new album, it plays cut #2 on the album I originally chose on my iMac.  If I go back over to the iMac and put iTunes into the song mode instead of the album mode and make sure the whole library is showing, i.e. don't have anything in the search field and then go back to the iPad, everything works fine.
   I started having this problem with iTunes 11 so there's definitely a compatibility problem.  I just checked the forums over at Audirvana and we're not the only ones with the problem.
http://www.audirvana.com/forums/viewtopic.php?f=5&t=295
 Damien has released a couple of updates to try to deal with this, but there still seems to be problems.  It looks like the only dependable way to use Audirvana right now is without iTunes.
morganc
FYI the Goldpoint attenuator is worth $200! Parts alone are more than the asking price.   Will include National 7DJ8.  $375 shipped!
srb
I think you meant for that post to go in your Trading Post ad for the Dodd Buffer.
morganc
Yes I did!  How did that happen :lol:?
TrungT
Long day and late night????  :wink:
