Sold: Rawson Built F5 Clone
0 Members and 1 Guest are viewing this topic. Read 1426 times.
Oscillate
« on: 9 Feb 2013, 06:08 pm »
SOLD: Rawson Built F5 Clone
I am the second owner, having purchased this amplifier in May of 2010 from
forum user 'cujobob', who had Tim Rawson build it for him. This amplifier was
to be used in a bedroom 2 channel system ...but that never came about. So it
is being sold to fianance an active cross-over, bi-amp'ed DIY main speaker build.
I have used this amplifier on several ocassions to drive my current speakers,
just to hear it play. However because those speakers are only 86 dB efficient, it
was impractical to do so for more than a few hours at a time. This amplifier has
spent it's time here, boxed-up and stored.
I will rate this amplifier 6/10 on fit and finish. As with most of Tim's work, it has
an industrial looking aluminum case. There are some minor scratches on the
face plate that would easily brush out if appearance is important. It has a Plitron
toroidal transformer and Vampire jacks/RCAs. No power cord is supplied with the
amplifier.
This F5 clone amplifier sounds fantastic. The bass is espcially tight.
One consideration to keep in mind is that this amplifier (like all class A amps) uses
quite a bit of electricity and runs hot. From the designer's web site, "Place the amplifer
in a well-ventilated location, as it draws about 180 watts during operation and requires
as much opportunity to cool itself as possible
". These two factors are the main reasons
I cannot use this amplifier for bi-amping my daily-user DIY main speaker build ...which
is a real shame when considering that I could not ask for a better sounding amp.
F5 Power Amplifier:
  • A push-pull Class A amplifier
  • 25w output into 8 ohms & 40w output into 4 ohms
  • 101k ohm input Impedance, single ended RCA inputs
  • Reported capable of driving low speaker loads (2 ohms)
  • Damping factor 60
  • Voltage Gain 15.3 dB
  • Power consumption 180 watts
  • Dimensions (including the feet & binding posts) H 5 1/2" x W 14 5/8" x D 11 1/4"
  • Additional information about the original F5 can be found at the designer's wbsite (1 2)
The price is Sold $550.00 USD (firm) plus actual shipping charges, insurance, signature
confirmation of delivery (and PayPal fees if applicable). Payment may be made by
USPS money order or PayPal. I will ship via USPS or FedEx only. Please use the
information and links below to give an accurate estimate of the total cost.
Parcel ships from zipcode: 43082
Parcel weight: 21 lbs. 4.5 oz.
Parcel dimensions: 9 1/2" x 13 1/4" x 20"
FedEx
USPS
If you would like to purchase please send me a PM.
This amplifier has been heavily padded with styrofoam & bubble wrap and then
double boxed. All edges and seams of the parcel have been reenforced with
generous amounts of packaging tape. I take packaging seriously.
...thanks for reading :)
« Last Edit: 4 Mar 2013, 04:50 pm by Oscillate »
frperdurabo
Re: Sold: Rawson Built F5 Clone
« Reply #1 on: 10 Mar 2013, 01:49 am »
The amp is here and it's great.  Looks better in real life than in the pictures, and O is a great seller.
This is by far the best solid state amp I've ever owned.  (Owned tube amps from Arc, Cary, Fi, etc and thought I was a tube guy for life - but this thing drives my Spendors like nobody's business)
