0 Members and 1 Guest are viewing this topic. Read 7229 times.
I have finally gotten all of my albums ripped onto the Mac Mini, which took a lot more time than I thoughtit would… 1340 albums totaling about 880 GBs.So far I tried both the "Audivanna Plus" and "Amarra" music players and both sound good and both workgreat while using the "remote" app on my iPhone and iPad.For DAC, I ended up going with the KingRex UD384 DAC and matching U-Power supply.I think I prefer the Audivanna Plus music player, it seemed to have a slightly bigger sound and I like thescreen interface a bit better… but I would be happy using either.The sound I am getting is very good out of the UD384, but I am having a slight problem.During playback I am hearing a slight "tick" or "pop" every once in a while as the song plays.It reminds me of how static pop might sound on a vinyl record.The pop is only noticeable during very quite passages of music, but this really distracts my ear as Iam enjoying the music.I was getting this with both the "Audivanna Plus" and "Amarra" music players.I think I have ruled out the problem coming from the music files or the Mac.When I play the music via the headphone jack of the Mac directly to the amplifier (no UD384)I am not experiencing the "pop", "tick" sounds.Perhaps there could be some settings that I do not have set correctly that maybe causing this?Could there be a problem with the UD384 or U-Power that is giving the "pop", "tick" sounds?If we can solve this problem I am sure I will be loving the sound of the UD384 for a long time. Thanks in advance guys
I had this same exact problem recently. Turned out it was the new USB cable I added that was responsible for the pops and ticks. I didn't even care to test the cable since it was a highly respected brand. I then emailed the vendor and he told me that the older version of their cable had dropout and noise issues with some DACs. Try a different cable would be my suggestion, hope you find the solution soon!
That's unacceptable. Indicative of a major design flaw. USB cables have a standard. Get the standard right, then add the fairy dust.
