Cary 7.24 250 watt/channel, 7 channels. - SOLD
0 Members and 1 Guest are viewing this topic. Read 2007 times.
ua100k
    • Merrill Audio
« on: 7 Feb 2013, 10:34 pm »
Trade up unit.
$3,500.
Original Box.
Single-ended RCA or XLR balanced inputs
250 Watts/8 ohms; 400 Watts/4 ohms
Remote trigger (works with +3.3 to +24 Volts DC)
Protection against short circuits, device failures, mis-wiring, and internal faults.
DC offset protection
Matched output transistors
High power supply voltage for extra headroom at the outputs
Stable with mismatched, reactive or unusual loads
Soft start circuit prevents “Brown outs” when amplifier is turned on
Solid State, Class A/B
Power Output:   7 x 250 watts @ 8 Ohms from 20 Hz to 20 KHz
7 x 400 watts @ 4 Ohms from 20 Hz to 20 KHz
Input Sensitivity: 1.25 Volts RMS Unbalanced 2.5 Volts Balanced
Frequency Response: 20Hz - 20KHz +/- 0.1 dB
Signal-to-Noise Ratio >100dB "A" Weighted
Input Impedance:   >10K Ohms unbalanced >20K Ohms - Balanced
Voltage Gain 28 dB
AC Power Requirements 117/234 Volts AC @ 50/60 Hz
Break-In Time 100 hours of playing time
Finish Black epoxy coated steel chassis
Silver anodized aluminum faceplate (black optional)
Weight 105 lbs Dimensions 8.7"H X 17.7"W X 19.6"D
Audio Input 7 RCA, 7 XLR
Audio Output:   7 pairs of heavy-duty, gold-plated binding posts THD: Less than 0.05% at rated output
Crosstalk: Greater than -90dB from 20Hz to 20KHz
Damping Factor -Greater than 270 from 10Hz to 400Hz Slew Rate: 40V/mSec
Remote Trigger 3-32v DC at 5 milliamps or greater
« Last Edit: 14 May 2013, 01:00 pm by ua100k »
azhtnut
Re: Cary 7.24 250 watt/channel, 7 channels.
« Reply #1 on: 14 May 2013, 05:04 am »
Is this item still available?
ua100k
    • Merrill Audio
« Reply #2 on: 14 May 2013, 01:00 pm »
Sorry, Sold.
